Question about Vacuums
TriStar Vacuum Nozzle Pivot Elbow replacement
I would like to know if someone could tell me how to replace this part. I have the new part but am clueless as to how it slips into the slots!
  • Tracy Earp
    Tracy Earp Feb 13, 2008
    Thank you for answering my call for help Yalmer.
    I did figure out how to get the Nozzle Pivot Elbow on eventually!
    In order to replace that part, it is required to remove both the bottom plate and the top cover of the Turbo Brush. That way it creates an opening from above to the slots where the Nozzle Pivot Elbow sits. The screws for removing the top cover are located inside the Turbo Brush which is only visable after removing the bottom plate!
    Once I found the screws inside the Turbo Brush, it was all downhill to repair!
    Once again, thank you for trying to help.
Look inside the two rear wheel slots. You will find the two retaining screws that hold the unit together.
Posted on Jan 24, 2009
Have a tristar exl. Want to install a new plug/cord however cant figure out to open up the vacuum? I found the 2 screws on the bottom, but after removing them, the vacuum still will not come aprt. Not sure if the white bumper guard is holding it together. Any ideas.
Posted on Jun 07, 2008
  • Don Troudy Nov 26, 2013
    Turn the vacuum upside down and remove the cover plate on the bottom of the unit. There are two retaining screws that hold the cover plate in place.
  • 552 Answers
Is tis vacuum elbow the on on the power nozzle?
Posted on Feb 12, 2008
Power head cord repair
Hi Kathy,
I don't know what model of Tristar vacuum you have but I have a tutorial in the link below that explain how to replace the cord.
http://www.diyvacuumrepair.com/cansiter-vacuums/how-to-replace-a-cord-on-a-tristar-vacuum-cleaner/
hope that helps.
Jan 15, 2016 | Tristar Vacuums
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mick
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
We have had the power wires that run through the swivel elbow at the end of the main handle extensions and the power head break after being repaired two times. The new swivel elbow and wiring connection...
Have them replace at the Aerus Electrolux shop. Aerus uses a higher grade plastic (Lexan, read about it on the net) which should last the life of the the power nozzle and wands. The part and labor will have a 1 year warranty.
Nov 15, 2010 | Electrolux Epic 6500 Vacuum
Where can I obtain a new tristar SB steam buggy nozzle from?
www.ApplianceZone.comLowest Prices On Appliance Parts Same Day Shipping Only $5. This place claime to have the parts needed.
I hope I helped.
Nov 06, 2010 | Tristar SB Steam Buggy Vacuum
The nozzle is blocked up i'm assuming with limescale. I've tried soaking it in descaler but it still won't work. The buggy is working but need the nozzle for any sort of power.
If you can not get the power nozzle to work then the best thing to do is take the nozzle to the local vacuum store(used) and they will tell you the best advice weather it be fix the old one or replace the head. You can pick up a brand new head for around 99.00 up to 350.00 depending on what you want and they have come a long way in the past few years so take a look at a couple new ones.
Oct 07, 2010 | Tristar SB Steam Buggy Vacuum
Carpet attachment with beater brush not working
Resolution for Quick Connect Power Nozzle: If you're vacuum is 2001 prior, chances are one of the two contacts in the power nozzle elbow have let go.
The elbow can be disassembled by removing the two screw covers. You will need a flat head and small star. Also, you need to release the retaining clip on the back of the elbow. You will have to remove the elbow completely if it needs replacement. You will then have to remove the top cover of your power nozzle. That is easily done by removing all screws in the bottom base of your nozzle. Once you remove your cover you should see 2-4 screws holding in the elbow
When you remove the cover, you will see metal contact rings and two contacts. If one of them isn't contacting the ring your power nozzle will not turn on. You can try shaping it back into place but from experience the new revised elbow that does away with that kind of connectivity is a lot more effective. The new elbow runs about $40-$60. Between eBay and Aerus Electrolux Dealer.
http://www.ezvacuum.com/electrolux-power-nozzle-elbow-assembly-graywhite-p-3542.html
Jul 12, 2010 | Electrolux Centralux Vacuum
My friend has a Tristar MG1 vacuum. The cord was
Chances are that there is the tiniest fray of one of the wires touching somewhere. Since you have already made a good repair with nuts and tape, feel the length of the cord for other bite marks where a puncture might short the cords. If you find such a site, **** the sheath lengthwise, tape the wires and replace them in the sheath, then tape the sheath closed.
Regards, --W/D--
Aug 10, 2009 | Tristar Vacuums
Need new nozzle
Ebay ... but you can probably buy an entire new Steam Buddy for the same price.
Jan 21, 2009 | Tristar SB Steam Buggy Vacuum
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
421 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
