Question about Cameras
Memory Card Error
Hi!  I have a Canon PowerShot S400 digital Elph and I'm getting "Memory Card Error" when I turn the camera on and when I go to view my saved pics it also says "Memory Card Error".  I replaced my original memory card yesterday thinking it was just old and I thought the problem was fixed because I was able to take pictures and they seemed to save ok but then today I turned my camera on and now it's saying "Memory Card Error" again.
  • 398 Answers
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Posted on Feb 12, 2008
I keep getting a error that reads memory card error, i've tried different ones(cards)with the same result.
You may only need to format the card in the camera. This will erase it so download any pics first.
Mar 22, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
Oct 21, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
My Canon powershot s400 camera won't read memory card
First, remove the card, and look in the slot for any bent flash card pins. If you see any, don't fret, it's possible that you can fix this yourself. See this article on how to unbend flash card pins.
But if no pent pins are seen, then the camera's clock battery has worn out, and is likely causing this problem. Unfortunately this battery is internal to the camera. But Canon will fix this for you (for the S400 only) for free, with free shipping. Please see the Canon advisory for your camera here.
Sep 12, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Memory card is defective error message
Format the memory card on the same camera it is not a battery problem &also reset your camera
Sep 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
What Can I do when my pictures are coming out pink?
its probably the settings. try changing the camera mode
Mar 05, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Memory card error
Solution:
1 set date to 31-12-2030 23h59 and switch camera off.
2 wait two minutes, day will be 01-01-2003 and camera asks you to set the date
3 take away memory card
4 set the date to today
5 insert memory card again
Now your error should be solved.
Sucess, Jonny
Nov 09, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon ixy 900 problem
Test the card with USB reader to see if it is camera or card issue.
Aug 15, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Cameras Logo
207 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
