Question about ASK Proxima C170 Multimedia Projector
No image appear
When i connected with vga cable into projector. no image appear.
DO NOT OPEN THE PROJECTOR!
First thing.. if the projector is on and you are seeing the projector menu, logo screen, input, etc. then your problem isnt the projector. Toggle your laptop video output via Function Buttons.
Dell is FN + F8
IBM is FN + F5 (i think)
Otherwise call a professional. Dont listen to these idiots. They will cause you to destroy your equipment or worst get HURT!
Posted on Apr 16, 2008
  • 44 Answers
Does your projector detect on ur machine !. your machine recoganize it or not !. ensure the vga cable is ok.if everything is ok then if you can open the projector then check the power unit inside and the voltages applied to the processing unit. this is sometimes due to low voltage or power supply problem.the lamp and controller unit are different from each other. there must be a switiching problem inside. if you can open it then well n gud otherwise u have to take it to the service centre......
Posted on Feb 12, 2008
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
My Panasonic PT LC76U has horizontal pixelated lines. See image at this link http://abigproduction.us/_images/panasonic.jpg
you need to check:
the Vga cables if the image shown is that from a computer
firstly check if the Panasonic logo comes ok in the beginning
if ok then try connecting a laptop directly thru a short patch cable to the computer port of the projector[i am assuming that the projector has been installed to the ceiling]
if this works ok , then the projector is fine!
you need to figure out the problem with the vga cabling and switchers if any of them are used!
Dec 30, 2012 | Panasonic PT-AE900U Multimedia Projector
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But...
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Aug 26, 2010 | Canon LV-5210 Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
How do I connect to my projector
If your dell is equipped to do this it is on the back side and appears as a video card connector or s-Video out. It is possible that your Dell is not equipped to make this connection, I have found a few that are not.
Oct 12, 2009 | Dell Inspiron 1300 Notebook
Can't obtain images from computer, can not find installation icon, would like instructions on proper cable connections
all you need is vga cable from monitor out to vga in on the projector. or dvi to dvi. the usb is for control, not for image.
Sep 10, 2009 | InFocus ScreenPlay 5000 Multimedia...
Display has a green tint to it tho it looks fine on the laptop.
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loose cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Jan 21, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
ASK Proxima C170 Multimedia Projector Logo
157 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
