1996 Nissan Pickup Logo
Posted on Jan 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How often should you get engine belts replaced and what belts need to be replaced?
joyellowhors
Level 2:
Sergeant:
Champion:
  • Expert 303 Answers
  • Posted on Jan 19, 2010
joyellowhors
Expert
Level 2:
Sergeant:
Champion:
Answers
303
Questions
Helped
124745
Points
669
Replace belts as needed, check for cracks on the sides of the belts or pieces missing from belt. A good belt should last 100,000 miles. and it is a good practice to replace at 100,000 even if it looks good. REPLACE ALL BELTS as needed.
Is it easy to replace a snapped belt, on a pye cd06 elec dryer, how much is a replacement belt, aprox
* V-Belts (older cars) are cheap $3-10. Even cheaper if you buy more from on-line sites like Amazon.com or WalMart
* Timing belts a lot more $25-40. But the problem is not the belt but the labor needed to replace the belt. Like a Head gasket for $5 but +150 labor to replace (remove engine components and remove, clean head)
* Chain timing belts and internal timing bells are more along with the added precision labor (it's inside the engine block)
* What caused the belt to snap? Worn belts can probably be replaced as simple wear and tear. New broken belt is cause to check for engine lock up, broken parts, Heavy part (from road) damaged under carrage. Need to have a mechanic check.
* Be safe. Have a qualified Auto Mechanic check and service your car.
* Check your warranty. Call for service.
Aloha, ukeboy57
3helpful
2answers
Timing belt replacement for 2001 Kia Sephia
For California models recommended at 105,000 miles.Belt needs to be inspected at 60,000 and 90,000, miles and replace at 105,000 miles.
Except California replace at 60,000 miles. Note 1.8L engine is a interference engine, if timing belt goes bad will cause major internal engine damage.
1helpful
Do I need to replace a timing belt or chaing?
Timing belt maintenance is extremely important! All Neon models utilize an interference-type, non-free-wheeling engine. If the timing belt breaks, the valves in the cylinder head may strike the pistons, causing potentially serious (also time-consuming and expensive) engine damage. The recommended replacement interval for the timing belt is 102,000 miles (163,000km), or sooner.
4helpful
4answers
Unknown millage on timing belt 152000
The interval for replacement is 60,000 miles on that model.
If you do not know the last time it was changed, it would be a good idea to do it so you do not risk getting stranded.
The engine is NOT an interference engine, so the engine will not be damaged if the belt breaks; you will just need a tow truck to get it somewhere to install a new belt.
4helpful
4answers
Timing Belt broke while driving my 96 Toyota Rav4, 2 wheel drive. Mechanic said that Rav has a zero tolerance engine and engine will need to be replaced. The timing belt has 55,000 miles on it and we were...
Zero tolerance means the valves may have hit the piston when the timing belt broke. I would suggest doing a cylinder leakage test to see if the valves are bent or not. If the valves are not bent then you can replace the belt and everything will be ok. If there are bent valves then the cylinder heads will need to be removed and repaired.
29helpful
4answers
Timing Belt Replacement+Diagram
How to replace engine belt 1999 ford escort
5helpful
2answers
Diagram for fan belt repair
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
51helpful
5answers
Serpentine belt replacement
2.0L Engines
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
