Question about MyMusix PD-6030 MP3 Player
MyMusix PD-6030 MP3
1) When I have my Player connected to my computer it never gets out of the Do not unplug the player phase.
2) When I try to start player it goes to a funny window (which won't stay on long) and shuts right back off.
Do I need to re-format and if so how?
  • 8,596 Answers
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check www.mymusix.com for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Posted on May 24, 2008
MyMusix PD 6030 persistently displays flash error! please backup the data and format the player. This happened after I tried to replace an existing playlist with a new one.
I would recommend you do back up your files to the computer and then format the player.
Q: How do I format my PD-6030?
A: There are various way to format the PD-6030.
With Windows XP, go to Start, All Programs and select 'My Computer'. Then see if there is a device called an 'Audio Player' listed there. If so , open the Audio Player and right click the item named 'Internal Storage' and select 'Format'. Once the format is complete, unplug the player and turn it on. Once it turns on and says 'No Files' plug it back in to your PC and add the music back to the player.
With older version of Windows, the player will show up under 'My Computer' as a 'Removable Disk'. Right click that and select "format'.
Oct 16, 2009 | MyMusix Audio Players & Recorders
Flash error backup data and format
just connect it to the computer then save all ur folders to ur desktop thats the easy way to back up data
May 15, 2009 | MyMusix PD-6030 MP3 Player
My mp3 player wont turn on
This might be a tricky one to solve - may take more than one method.
Start by resetting the player. Then replugging it into the computer.
If it still fails:
Uninstall the PD-6030 via device manager. The PD-6030 needs to plugged in to do this. Go to Start, Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'. Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates
correctly. Also, performing a firmware recovery procedure can work to make your computer recognize the PD-6030. Please follow the set of instructions titled, "Q: How to recover my player's firmware?".
The firmware upgrade can be found at www.mymusix.com
-Tha Mp3 Doctor
Jun 13, 2008 | MyMusix PD-6030 MP3 Player
What is a I/O error
Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> device Manager - see if there are any yellow exclamation marks by the player and follow Windows troubleshooting
If the fails, you will need to restore the player's firmware - the instructions are too long to post here, but they can be found at www.mymusix.com on their pd-6030 page - click-by-click with pictures - very detailed.
-Tha Mp3 Doctor
Jun 05, 2008 | MyMusix PD-6030 MP3 Player
PD-6030 MyMusix problem
It could be a hardware issue, but you should at least try reformatting the player: There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
-Tha Mp3 Doctor
Jun 01, 2008 | MyMusix PD-6030 MP3 Player
MP3 PLAYER JUST SHOW MYMUSIX, WON'T GO TO MENU
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Apr 23, 2008 | MyMusix PD-6030 MP3 Player
Display Light
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Jan 17, 2008 | MyMusix PD-6030 MP3 Player
It shuts off when i connect to the usb
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Dec 16, 2007 | MyMusix PD-6030 MP3 Player
Mymusix pd-6030 player
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 29, 2007 | MyMusix PD-6030 MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
MyMusix PD-6030 MP3 Player Logo
93 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
