Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
HP ZV5000 When I plug in the AC adapter the power indicator (lighting bolt) comes on for 3 seconds and then shuts off. It should be noted that the battery stop taking and holding a charge a while back so the computer has only been working when the AC power was plugged in. Then the other day... the computer shut down in the middle of operation. If you unplug and replug the power cord into the computer the lighting bolt comes on for 3 second then turns off. Any ideas or suggestions
  • 9 more comments
  • Anonymous Feb 14, 2008
    I have a zx5000 series exhibitign the same behavior
  • Michael Paul Mar 20, 2008
    When I insert the power cord into the laptop it make a static spark sound and the lighting bolt and the plug in light only would stay on it you pushed it in the laptop and held it there. This made it really hard to type. Now, no matter how hard you push the power code in or what position you hold it in no power get to the laptop.
    I bought a new power code thinking that it was the problem and it was the same thing. I think now that it is the female plug, but I do not know how to take apart my laptop and I am afraid that I will cause more problems by trying to replace the plug.
    What should I do?
  • mahon655 May 08, 2008
    i have had the same problem and read other forums basically they said hp will ignore this problem because it is a design fault (cheap parts) it is to do with the power board if you can get access to it you need to be an expert solderer and it is only a temporary solution as the solder will wear . i am told that eventually the power won't work at all and the battery will not charge i have had this problem for over a year now and it still hasn't been solved and the only people who can help ignore you and blame it on the operating system and advise you to reformat your hard drive i have done this but to no joy and anyway as far as i know anyone who owns a zv5000 will have the same problem so it comes down to choosing the wrong laptop but i will still look for a solution
  • joye2000 May 17, 2008
    I have the same problem. My laptop keeps shuuting off. I brought a new ac adapter but that did not stop it fro shutting off. The battery power will say 100% and still shut off. I would have to press the adapter into the laptop for it not to shut off but I feel alot of electricity running through it so this solution is not a good one.
    Please help!!
  • Ike C Jun 02, 2008
    HP has been sued in Federal Court in a class action suit because the HP Pavilion zv 5000 has a defective power port. I had mine repaired in 2004 and it cost me nothing to fix because it was under warranty. Now the same problem has come up. In my opinion this model is a LEMON. HP should compensate buyers for this defective product.
  • gspot82 Jun 17, 2008
    I had the exact same thing but in my case I think it might be a defective battery as well. The things do wear out after a few years because it will go from 100% down to zero in about a half hour.
  • budcluf Jul 31, 2008
    I am told that a xc 1000 media cable will fix the problem, good luck finding one...
  • joelgilb Aug 12, 2008
    Same problem with a zx5000 and now can't turn the laptop on at all. way past warranty and now not even sure if it is worth paying to get it fixed.
  • glosol Sep 05, 2008
    3 seconds of lightning bolt. Hit power button and it gives 2 lights indicating power on, then shuts off.
  • Peggy Blass Sep 05, 2008
    I have had the same problem and followed advice from HP and ended up buying a new battery. This did not fix it. I
  • Anonymous Sep 14, 2008
    i have the same exact problem!!! and hp told me it would cost $398 to replace the motherboard is it worth it do you think?
  • 185 Answers
For all those with the ZV series power jack problem, I have replaced a few of these jacks and it is not an easy job unless you are an engineer.
The entire laptop needs to be disassembled, all the panels need to be removed, including the keyboard and you almost have to remove the motheboard.
Even when you eventually gain access to the offending part, you will need to be competent in using a soldering iron to remove the jack without damaging the printed board, then clear the holes so the new jack can be fitted.
While you are doing all this, you need to remember that the circuitry is static sensitive. This means that you can kill your motherboard just by touching it.
When you have finally finished the job, unless you have been pretty smart, you'll end up with a box full of different size screws and you won't know what goes where!
With the ZVs I have repaired, I usually supply a short jumper lead that plugs into the power jack on the back of the laptop. This is two or three inches long with a cable power socket on one end and a power plug on the other. This means that the user can leave the power plug plugged into the laptop all the time and just disconnect and reconnect the power unit from the other end of the patch lead instead of wearing out the laptop's power jack.
Posted on Sep 13, 2008
  • 29 Answers
Beyond what others have said.... It is important, if you try to do this repair yourself, that you use a High-Temp solder, say 450 F or your repair will slowly melt down and require re-repair after a month or two of use. Normal solder is rated around 250F (give or take).
I make this point from personal experience having repaired a few of these types, both compaq and HP labels. The basic design is terrible, and if you trip over the cord, it will easily crack the power port, or at least cracking the solder points on the motherboard, mandating replacement.
My HP zx5295US came to me with its power port damaged. I got a new port off ebay for like $10, and did the repair, unknowingly using solder with too-low a temperature rating, and had to re-do the repair after about 6 weeks. This time I used the 450F (or so) solder and so far the re-repair has held having seen pretty heavy use of this laptop including a new battery.
Just my 2 cents....
SD1
Posted on Aug 03, 2009
I have the same problem with my zv5000. HP started using the cheapest material and labor, and so they screwd up the company and decided to buy face, so they acquired Compaq. I hope they don't screw up Compaq too.
Paul, Nashville, Tennessee
Posted on May 22, 2008
Monitor card unknown
Posted on Apr 11, 2008
The power jack on the hp series of laptops is rubbish which is fundamentally the root cause of all your problems.... visit the following for help and advice....www.ikenfixit.com or see these similiar problems and reviews......
http://www.notebookforums.com/thread63874.html
Hope this helps as I have the same prob on my sons laptop and am about to hardwire the cable to the board or fit another adaptor - but fancy a hardwired short lead with external adaptor....
Posted on Apr 07, 2008
    Problem Solver:
  • 19 Answers
Maybe the battery connector on board have Cracked traking. Have to resolder it. Good luck
Posted on Feb 20, 2008
2 Suggested Answers
SOURCE: No Power - Power Indicator 3 Seconds
Power jack is not faulty. It merely comes loose from the circuit board.
Posted on Nov 08, 2007
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
Shut off and won't come back. It's like it is dead.
follow this procedure:
1. unplug the ac adapter and keep it unplugged.
2. Remove the battery and keep the battery unplugged.
3. Hold the power button down for 15-20 seconds(Nothing will appear on the display and none of the lights will light up)
4. Release the power button and plug in the ac adapter ONLY. (A power indicator light should be lit on the ac adapter when it is plugged in)
5. Normally power on the notebook.
6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
7. Plug the ac adapter back into the system, the battery charging indicator light will light up. If the battery indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Char S.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
HP Pavilion Laptop zv5000 wont power on. NOT power cord problem.
I think your motherboard has gone bad, even though you hear a fan working, its just on a hot wire on the motherboard.
Dec 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hp laptop won't turn on at all
HeHe.... My grandpa called me because he was having this problem. After searching the internet, I asked him to check the power cord - sure enough the two pieces of the cord had come separated. The computer wasn't plugged in!
Nov 30, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
My hp pavilion
Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board:
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button .
  5. Is the Power indicator light (LED) on or off?
****If notebook power indicator light (LED) is on, the AC adapter is working correctly***
If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the AC adapter to the wall outlet.
    • The connection into the power adapter from the wall outlet.
    • The connection from the AC adapter to the notebook.
  3. Press the power button again to test the notebook PC.
  4. If the power indicator does not turn on, remove the AC power adapter from the notebook PC and re-insert the battery. Then press the power button. If the power indicator light still does not turn on, then the AC Adapter needs to be replaced.
*****Reseating the RAM may resolve this issue.****
Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. After removing one module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
fter the memory is reseated, connect the AC adapter and turn on the notebook. If the notebook boots normally and the Windows desktop appears no further action is needed. If this problem re-occurs often, contact an HP Support Specialist to schedule a repair.
Aug 12, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
This line of hp notebooks is the most notorious for power jack issues. There a re a few different symtpoms but 95% of all problems can be fixed with a power jack resoldering or replacement. It very rarely damages anything else on the motherboardis and seldom has anything to do with the power adapter/supply itself. There are a few options:
1) take to computer repair shop and get new power adapter. (As this requires a complete tear down of the notebook, it can be a bit expensive in terms of labor. The part is less than $10 on ebay and is readily available. You can download the service manual and break down the notebook yourself and take just the mb and new adapter to the shop and save some money. I don't recommend attempting to soldering on the MB yourself
2) If you don't need portability as much as just being able to use the laptop at home, then purchase an xb2000 expansion base from craigslist and power thru the docking port on the side. Be sure and confirm that the adapter is included with the purchase as some owners may have discarded it since their particular model didn't need it.
3) If you can manage to get an XC1000 cable for a reasonable price off ebay or craigslist, this is a portable option. However, as they stopped making these All-In-One media cables a while back, those who have them know their value and command a pretty hefty price. I personally would rather pay a computer repair shop a $150 before I pay some person who capitalizes on my misfortune.
4) I am in the process of confirming this least expensive solution but I don't see why it wouldn't work.
-- adapter from the xb2000 expansion base (you can pick these up cheap or free)
-- xc2000 all-in-one media cable ($35 - $50)
-- 120w power adapter for Presario R4000,R4100, R4200, and Pavilion ZV6000 (oval shaped multi-pin connection required.) Note: The original lower wattage adapter will not work. ($25 - $30)
Although this solution may cost a little bit depending on how creative you are, you can sell your old power adapter to offset the cost of the new adapter AND you can sell all 3 for what you paid when the laptop dies completely.
5) the paper clip trick has been known to solve a few problems where the connection in the socket is the problem
Ultimately, you can purchase a MB and replace it your self, the MBs run around $150 and you can use the service manual to break down the notebook. However, this is only a recommended solution if you have video problems since breaking down the laptop is just time consuming and the soldering of the power adapter is cheap
Oct 14, 2007 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
2,707 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
