Question about Dryers
Dryer does not heat up
all the sudden, in the -20 degree temps we enjoy here in MN, our dryer is not producing hot air. It turns on just fine, all teh electronics work - the display, etc. But no heat. It is a gas dryer. Thats all I know - here are the details:
Kenmore Elite - at least 5 years old, was here when we moved in
model # 11072062100
This dryer has run daily at least once for the past 5 years - 4 kids.
Any ideas?
Thanks!
LMP
My dryer has a knocking sound it may have something stuck in it what should we do to retrieve the item
Posted on Aug 09, 2008
  • 240 Answers
Sounds like you might have the gas coils going bad. Not that expensive for repair, and parts arent that much either. Worse case would be a control board has went bad, but not likely. Gas coil part number is : 694539, and 694540. Also, you may want to check to see if the ignitor is glowing, that part # is 279311. Good luck and let me know if that doesnt help you.
Posted on Feb 12, 2008
The dryer is getting very hot and then the timer appears to be sticking at 20 mins to go. I have changed the thermostats already.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Mar 16, 2015 | Hotpoint Dryers
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 17, 2015 | Dryers
Why is an Asko 7304 dryer running hot, so much so it melted fuse holder?
GOD IS still GOOD !!!!
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 16, 2014 | Asko Dryers
I have a Kenmore 700 series dryer that runs 20 minutes and stops. What do I do?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 18, 2014 | Dryers
I have a GE Profile Harmony Dryer # DPGT750GC1PL and it is not heating. I saw a while ago that you had a responded onfixya.com there you offered to send someone the service manual. Can you email this to...
Some times the thermostats on the hot air channel are faulty. Check with Ohm Meter for continuity. If negative, replace and enjoy your dryer.
Dec 01, 2017 | Dryers
I just installed heating element ,and it seems to be to hot . i am wondering if there is a senser or switch that regulates it from getting to hot
That sounds like a venting problem. Check to see if the vent is crimped from pushing the dryer back on it. Also check air flow outside. The blower may be failing.
Also check the temp out side at vent. Should be about 155 degrees
give or take 10 or so degrees. If you have good air flow but the temp is too high then you need to change the operating thermostat
(in back)
Leo Ponder
imufo2@sbcglobal.net
Jul 27, 2010 | Whirlpool LER4634J Electric Dryer
Dryer suddenly does not produce hot air
have the exact same problem, just over 1 year old no heat! first off my duct work under my floor is like a snake and is not a straight shot out of the house. I beleive this caused a ristriction in the venting because dyer seemed to be running hotter them normal. I took the top off the dryer and pulled the vent tube out of the bottom of the dryer. To my surprise found a three inch layer of lint on the bottom of the machine and also on the heating coil. After cleaning out all the lint i took a volt meter to the two wires that come down to the heater. started the dryer and found i had 220volts at the heater indicating the heater is out, found one on ebay for about 50 bucks. will be installing this weekend and will let you know how it works.
Mar 08, 2010 | Samsung DV218AEW Electric Dryer
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
Dec 15, 2009 | GE DBXR453EV Dryer
Dryer stops after short time
I believe your exhaust duct with five 90 degree turns has weakened the limit switch in the exhaust pipe where the hot air leaves the dryer. Let me know if taking the hose loose will increase the dryers time. If not then we will need to replace the limit switch. Let me know as i will be able to help you further. Please visit my site Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
My dryer won'y blow hot air
bpaul...first, check to see if you have full power to the unit. These units run on 220 volts which involves two breakers linked together...my guess is one popped and you're running on 110. You'll get some functions but not full heat. Turn the breakers off and back on. Not it? Then check for lint in the piping which is causing a false reading on your temp sensor.
Dec 17, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
226 people viewed this question
Top Dryers Experts
Marvin
Marvin
