Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Handle loose on Refrigerator
The door handle on the freezer is loose and the fridge is only 2.5 years old.
  • 1 more comment
  • Anonymous Mar 14, 2014
    It is old and some numbers are gone. It has a # ASK175MN8W and a serial # 069R119087 and ASK171MN
  • Anonymous Mar 18, 2014
    My fridge freezer door handle has broken,how do I take it off
  • Anonymous Mar 29, 2014
    Freezer works fine, but fridge is getting warm. How can I fix this before loosing food?
  • 770 Answers
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Posted on Feb 12, 2008
    Top Expert:
  • KitchenAid Master
  • 14,486 Answers
Tighten it
Posted on Jul 08, 2017
    Problem Solver:
  • 4 Answers
Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
2 Suggested Answers
SOURCE: Handle loose on Refrigerator
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Posted on Jun 09, 2008
How to tighten a loose door handle for On the fridge upper half?
Gain access to inside of refrigerator door to refasten the loose handle.
Mar 06, 2016 | Bosch B36IT71SNS (20 cu ft) Bottom Freezer...
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Hotpoint side by side no dispensor door handle loose
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
Jun 17, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LOOSE DOOR HANDLE ON GE PROFILE ARCTICA STAINLESS STEEL REFRIDGERATOR
I may need to know your model # from the sticker inside the fridge to view a diagram but usually there is are small set screws (usually 2) on the handle which are allen head that can be tightened.  Look for this first and let me know if there are no set screws.  If this is your setup then I would appreciate a solved rating.
Oct 18, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,874 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
