Question about Logitech Z-540 Speaker
Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
There was no problem for a couple of months, then out-of-the-blue - when I go to change volume (up or down) the volume increases to an extreme yet variable level and is crackly & distorted until I stop moving the volume knob
Mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Posted on Mar 05, 2008
  • blackpearlin Nov 21, 2010
    ummm you may find that the multi channel potentimetre/variable resisitor if you will may be dicky, mine was to i bridged across all channels with solder and just use the volume control in my pc, and for the dead speaker issue, sometimes you need to open the realek manager and ensure that you have selected the right spaeker for the output, mine was a pain, cause there were no instructions, but under test it progressively send a test signal to each speaker
How manage volume headphones in x-540
headphone Volume is controlled by the music app. Logitech Support
Feb 03, 2015 | Logitech X-540 Computer Speakers
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Speakers crackling and making a 'clicking' sound when volume high
The cable you are using to connect to the speakers could be duff or the connectors could just be dirty.  clean the connectors and push it in and out of the socket repeadedly to ensure you have a good connection.  Or you could try a different cable.
Mar 01, 2009 | Logitech Z-5300 Computer Speakers
Logitech X-540 Configuration Confusion
Your speaker system is designed for the 5.1 surround. *********** board manual shows you which wire goes to where.
Dec 13, 2008 | Logitech X-540 Computer Speakers
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
Logitech wireing setup for Z-540
i have realtek ac97 pci...someting like that..
Aug 01, 2008 | Logitech X-540 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Feedback sound, hissing , in speakers logitech X-540
You may want to try disabling/muting the microphone volume in the volume control. If it doesn't help please post back.
Feb 19, 2008 | Logitech X-540 Computer Speakers
Loud crackling / popping
Well gd stuart i think you need some new speakers
Jan 27, 2008 | Logitech Z-2200 Computer Speakers
Logitech Z-540 Speaker Logo
1,706 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
