Over-time, batteries will loose their ablilty to hold a charge. this can also happen if you leave it plugged in for long periods of time (known as over-charging)
only solution is to get a new battery.
Sounds like your battery is a bit faulty, but in saying that, an hour is well... sorta average... depending on what ya doing etc... Check out this link and see if that helps.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4YQJZV
Batteries are real swines of things, they react well to constant cycles, but hate hap-hazard charging, also, they pack up what seems real quick. If ya financial ya may like to try a brand new battery. Then make sure ya cycle the battery and set the ACPI setting correctly.
The older a battery gets, the shorter it will hold a charge.
Battery life is maximum 3 years.
