Question about Infinity Reference 5350a Car Audio Amplifier
Flashing Protect light
I have a new Infinity 5350a amp that i just installed in my car. I went to trun it on and nothing happened just the protect light was flashing. but then today when i went back out to try and fix the problem i was able to get some sound and when i went to turn it up it went up for a little bit then went back in to protect mode. what would make this do this? I have plenty of power going to my amp and I have everything wired correctly. any ideas??
  • ryanflem Feb 14, 2008
    I actually fixed it. It was a really easy fix and i feel stupid for not figuring it out sooner. My ground was bad.... easy as pie one would say....
    Problem Solver:
  • 8 Answers
What are u using to play music??
Posted on Feb 13, 2008
My reciever went to protect mode after my speaker wires touched. I removed all cables and power for an hour but stays in protect mode. I also changed 2 15 amp fuses inside but nothing unless I take fuses...
Yes, you can do this easily.
Perform the following steps
(1)Plug your amp to AC outlet.
(2)Switch it on.
(3)observe time taken for switching off.
(4)immediate to shut down over current protect(5)3 seconds to shut down DC protect.
If over-current protect do the
following steps
(O)unplug the amp.
(1)download NR806 service manual.
(2)open the amp metal cover.
(3)measure 7 large white resistors resistance loacated next to power transistors mounted on a large heat sink with black probe touching the middle pin and red probe to first/left or third/right pin.
(4)If this 3 Pins large white colour 0.22ohm x 2 resistor is open with infinity ohms ,
(5)replace it and jot down this channel for example left surround faulty. Usually only 1 channel went faulty.
(6)the two large power transistors next to this white resistor 0.22 ohms x2 should also be replaced.
(7)plug the amp
(8)switch it on
(9)if ok, troubleshooting get done
(10)if not ok
(11)replace ALL the components of this power amp channel.
(12)pre-amp section no need to check.
Nov 23, 2017 | Onkyo TX-SR806 Receiver
Protect light keeps comin on
MAKE SURE THE GROUND IS GOOD ON BODY OF CAR BOTH UNDER THE HOOD AND WHERE YOUR AMP IS GROUNDED
Apr 18, 2010 | Infinity Reference 1300a Car Audio...
Protect light comes on, no power
Hello patrick_h_mi,
You'll also need a remote turn-on source for the amp to operate. Normally, this is a blue or blue/white wire from your head unit, but for test purposes, you just need 12V to the "remote" terminal on the amp. The amp should power up without speaker inputs or speaker connections, but it is not recommended.
Hope this helps.
May 28, 2009 | Infinity 7540A Car Audio Amplifier
INFINITY AMP PROTECTION LIGHT FLASHING FOR 5 SECONDS
I have an Infinity amp as well, and I was having the same issue for a time. The amp is protecting itself from some sort of overload. It could be the Ohms load on the sub, but I would guess not. Make sure your low pass filter is set to LP and not HP or Flat. Then check the RMS on your subs and match that to the Amp RMS. Once I did all that I found that everything worked fine, for a time. It started doing this again, and I checked the fuse and it was blown badly. It seems that the fuse setup on some of these Infinity amps is not as good as one would hope, because the charge was bridging the gap and frying out my fuses. It was like a spark would jump from one side of the fuse to the other without travelling the fuse itself, and this was causing my protect issues. I pulled the fuse, got a new one of the same rating, but I placed the fuse in with a little piece of rubber in between the 2 contacts, and then connected to the fuse block. I have not had problems since.
Jan 28, 2009 | Infinity Reference 7541a Car Audio...
Protect Mode
first I would advise you to tighten all of your ground and power connections. Then I would suggest that you expose the circuit board and start the amplifier warm up process, once the amp comes on I would use freeze spray to cool down various components in an attempt to find the component which has become thermally sensitive. Once you find the component I would suggest replacing it and the putting the cover back on the unit.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 09, 2008 | Infinity 475A Car Audio Amplifier
Amp not working
Does it do the same thing if you remove the RCA input and disconnect the wires from the speaker terminals of the amp?
Oct 25, 2008 | Infinity Reference 7541a Car Audio...
Losing power
After reviewing the owners manual I can only guess that your amp is faulty and will need service. There is no reason for the power and protect lights to both be off while the power and remote wires are active. I'm assuming of course that power is still applied and remote is activated. It's difficult to diagnose problems online without voltmeter readings but my bet is on a faulty amp. In this case it will need to be professionally serviced. Before paying for service you could check the voltage at the 12V and Remote terminals, both should be 12volts. A solid ground is obviously required but it sounds like you have wiring covered. Feel free to post any updates and I'll continue to provide options if I can.
Sep 05, 2008 | Infinity Reference 5350a Car Audio...
No audio-amp protect light come on then went
You need to check the DC voltage across the B+ and ground terminals. You also need to check the DC voltage across the remote and ground terminals. If the voltage is less than 11 volts, you need to check the B+ supply and remote wiring for breaks or open fuses. You should also check the ground connection to confirm that it's not loose.
If the voltage is OK, the output transistors are likely shorted.
Oct 21, 2007 | JBL GTO75.2 Car Audio Amplifier
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
Infinity Reference 5350a Car Audio Amplifier Logo
254 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
