Question about Refrigerators
DRCOOL299 reply Answer to my compressor shut-off noise: could be a broken spring inside the compressor and would only make a noise as the compressor stops. nothing you can do about it. you would need to break open the compressor, replace the spring, weld it back, then charge it up again with refrigerant. This begs the questions: Will this cause the unit to self-destruct? If so, how soon? What may be the approximiate cost or time for a technician to perform the fix you offered? I suspect that repair may cost almost as much as a new refrigerator. Thanks!
  • 770 Answers
First off there are no springs inside a compresser and it is not really a serviceable part unless you get into semi-herm compressers (commerical units) the best bet is to replace the compresser and drier at a cost from $400-800 depending on the company If the compresser is your problem I never heard the first part
Posted on Feb 12, 2008
How do you fix a refrigerator compressor clunk?
The usual cause of this problem, especially on GE models, is that the compressor is bad. Specifically, the motor inside the compressor, which is supported by springs for noise isolation, probably has a broken spring, allowing the motor to hit the outer shell of the compressor when it stops. The good news is that it can continue to work with the broken spring for a long time. The bad news is it is essentially impossible to repair or replace the spring. You can have somebody replace the compressor, you can replace the fridge (not another clunker from GE), or you can put up with the noise, knowing that every time it clunks, it has just cooled everything inside.
Feb 15, 2015 | GE Appliances 17.9 cu. ft. Top Freezer...
Freezer runs on when on its side. When placed flat on the ground, i hear a grinding noise and it shuts down. It only starts back up when I lift it up on one side.
It sounds as if one of the suspension springs has broken. Inside the sealed canister is a conventional electric compressor. It is suspended inside the canister by 3/4 springs to remove vibration from cabinet. When you lay it over the compressor lays vertically (or horizontally when on side) as it should when properly suspended. I'm afraid it's a new compressor sphere or new fridge.
Des
Dec 01, 2014 | Refrigerators
Loud noise when unit stops. what is it?
Good day,
If it makes a loud clanking or rapping sound when shutting down, it is usually a broken spring inside the compressor itself. Pull the machine out when it is running and see if you can isolate it to the compressor itself.
If that's the case, there is no way unfortunately to repair it except replacing the compressor.
Oct 27, 2010 | Roper RT12VKX Top Freezer Refrigerator
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
The GE Profile of 13 years old makes a loud bang sometimes a few times a day after running awhile -- does it mean it is the compressor and time for a new refrigerator or could it be something else -- we...
Good day,
If it makes the clunk or banging noise when the compressor is shutting off, then yes, internal spring or springs inside the compressor have broken.
Only solution to that problem is a new compressor.
P.S. these things can run a long time with this condition, but ultimately .....
Thank you for using FixYa
Dec 25, 2009 | GE Refrigerators
Clunk noise when compressor shuts off
Good day,
Compressor has an internal problem. Usually caused by a broken centering spring inside the compressor housing.
Only solution is replacing the compressor.
The good news is they can run for along time that way.
Nov 29, 2009 | Whirlpool Refrigerators
Makes a shuddering noise when compressor turns off
It sounds like the suspension spring has broken inside the compressor so when it shuts off it rattles against the case. If the refrigerator is still operating normally I would recommend not repairing it. It could run for years like this without any further problems and a compressor change would be very costly.
Feb 24, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Kenmore fridge, about 8 years old, making noise
The compressor on your fridge is mounted on rubber grametts and inside the dome the internal parts the do the pumping of the refrigerant are mounted on springs. When a compressor gets old some people complain about two much vibrating, this could be the rubber grommets the support the compressor. When one of the support springs inside the compressor is broken it will have a distinct rapping sound when the compressor shuts off. There isn`t anything you can do about this, short of replacing the compressor. It will eventually get worse untill something is seriously broken inside the compressor and the compressor will die. You may want to consider replacing the compressor now or purchase a new fridge. You will need to consider the cost of both and the age of the fridge" Is it worth repairing?". You can actualy find a repair company in your area from this site if you like, and compare the costs.I hope I have helped explained the problem well enough for you. I will help you as much as I can.
Nov 15, 2008 | Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
