Question about Zenith Z50PX2D 50 in. Plasma HDTV
Black line Recently we are seing a black line across the screen. It comes and goes and is always in the same location, all channels. Thank you for your help Ana
  • ana1 Feb 22, 2008
    It is vertical and black.
  • ana1 Feb 22, 2008
    Thanks a lot. Please let me know if you know local technitians to fix the problem. We live in McAllen, TX.
    Sniper:
  • 67 Answers
Is it a vertical or horizontal line?
Posted on Feb 22, 2008
  • 2 more comments
  • clusterfx
    clusterfx Feb 22, 2008
    It is most probably one of the x-drive boards or the control board.
    there are three boards at the bottom of the pdp panel, the screen is divided into 3, the left and right boards control equal and a slightly larger portion of the screen than the middle. depending on where the line is, you can disconnect the corresponding board to see which one controls the area where there is a vertical line. Replacing that board will most likely fix the problem.
  • clusterfx
    I have circled the possible boards. I think you should also get a second opinion as i am not a pdp expert.
  • clusterfx
    this is a bigger view
  • clusterfx
    http://136.166.4.200/contents/Displays/P...
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Cannot safely remove
Hi there
I have not come across that problem with my portable hard drive. But I always look at "bottom line" where the icon for the hard drive comes up, click on it then look for the sentence "it is save to remove the device now" .
Hope that you will get a good help with that.
Kolbrun
Feb 29, 2012 | Western Digital WD My Passport Essential...
Vertical white bar across screen
Hello Sleitz ok want you to try acouple of things first lets change the ratio of the channels to 16:9 or 4:3 if the line is there regardless of you trying this procedure then try to disconnect some of the connections coming into your tv set like the cable,satellite connection ect ... and connect them back on just to see what happens also while trying this method keep an eye on the screen to see if it changes in some sort and the line disappears, if the line goes away then that was your problem, if the line is still there after trying the above procedures then this is a faulty front panel and this is expensive to repair, hopefully not lets keep our fingers crossed for it to be a bad connection to your tv set, thank you hope this helps.
Sep 01, 2009 | Vizio L32 32 in. LCD HDTV
Line on the Picture Screen
panel t-con parts n/a will most likley be replaced.
Nov 03, 2008 | Protron PLTV-32 Television
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Televison & Video
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
198 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
