Question about JBL GT1041 Car Subwoofer
High pitched noise comin from sub
When the car isnt moving they work fine but when i move or get on the throttle a high pitched noise comes from them when i am moving and i push the clutch in the sound goes away i have no idea what it could be
  • ziggy239 Feb 13, 2008
    besides being very annoying when its not drowned out is it bad for the subs or armp
I get a highy pitch sound from sub when i step on gas and also my sub goes crazy wen i turn on the bass to high i dont hnow wat it could be?
Posted on Apr 07, 2010
  • 883 Answers
If sound also goes away when throttle is released and sound returns when throttle is pressed down, then you have engine noise from car engine electronics. In older cars, this was quite noticeable when the cars had distributor caps. The electrical noise caused by arcing required for the spark plugs could be your issue. It is resolved with a noise filter which gets wired inline leading to your in-dash deck and power amp (if you have one). The filter can be found many places including Radio Shack and Crutchfield.com. First find your total wattage draw for each component of the sound system (deck and amplifier), then divide by 12 to get current draw through filter. Purchase that size filter or larger.
Posted on Feb 12, 2008
  • Marty marty Feb 13, 2008
    no. no damage to either sub or amp, just annoying. the filter should cost about 15 USD, depending on your location and filter size.
2008 Element. Runs like a charm, just had its BIG tuneup done this spring (tires, timing belt, etc). Makes a VERY intermittent high-pitched whine. Doesn't seem connected to anything-not just when cold,...
still bad? doing old zero answer posts. (my bag)
finding noise is hard, and takes skills and can be dangerous.
my guess ????? it makes noise only moving.????
only clue is front, and presume outside of car and not under dash.
if car makes noise moving only, it can be dangerous , driving or even trouble shooting.
does it make noise in turns, or bumps,or loads (hills) or in all gears. or down hill, or coasting.?????
when it starts, does letting of throttle stop it, or more throttle>
or down shifting.? or cutting throttle and shifting to neutral.
I added many check to Doesn't seem connected to anything
my guess is the whine will progress to full time, many times this is true.
good FSM cover noise, here is more.
(tools can do wonders.)
http://www.fixkick.com/NOISE.html
Sep 10, 2013 | Honda Element Cars & Trucks
I'm actually having a couple of problems with my 2002 buick century. The first of which is whenever I am driving my car there is a high pitched spuealing noise coming what seems to be the front passenger...
Good Evening. First off I would like to give you a little advice on your passenger side windshield wiper. On your windshield wipers there is a nut at the base of the arm, try tightening that nut down (of course while your wipers are off) and that should make it work going off the description of your wiper problem. Your Antilock and trac off are lights that are tied into your antilock brake system and will both come on together. Your high pitched squeal could be a few things like brake pads, or a backing plate rubbing. Your hub assembly really won't make a squeal but would be a good reason for the anti lock light to be on. Your best bet is to have the antilock system scanned for codes to know exactly what is making the system to pass a code. Any other questions please feel free to ask. Hope this helps.
Aug 07, 2010 | 2002 Buick Century
Got a high pitch squeel .
Jack the front of the car up then spin the wheels this will give you alot better idea of where this noise is coming from. Check the brakes agian and the wheel bearings.
May 17, 2009 | 1998 Ford Ranger SuperCab
High pitched noise, engine shuts off at idle
You need fluid!! The high pitched noise yu hear is air in the hydraulic sections of the transmission. Top up the fluid then find out where the leak is
Good Luck
Mar 14, 2009 | 2000 Ford Escort
1999 Honda Passport 4x4 auto intermitent high pitch winding noise
try checking the tension on all the belts(fan/water pump, power steering, alternator). If loose, they'll whine.
Feb 26, 2009 | 1999 Honda Passport
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Feb 14, 2009 | Polycom VSX 7000 Video Conference
Jbl 15" sub
umm. i think you having some driver problems. how many watts you put it? do you have a filter? if you have one install it or turn it on. lets see what happends.
Nov 10, 2008 | JBL GTO1202D Car Subwoofer
High pitched noise comin out the sub
You may have a ground loop issue. Make sure your ground lead is as short as possible (<1ft, if possible) and that it is mounted to a nice, clean (unpainted) spot on the vehicle. If you have multiple amps, try and ground them to the same point.
Mar 07, 2008 | Fusion FEW12PK Car Subwoofer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
JBL GT1041 Car Subwoofer Logo
318 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Morne Olivier
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
