Question about Whirlpool Duet GHW9150P Front Load Washer
Random electrical problems, sometimes it works beautifully, sometimes not!
The last two loads went thru the washer perfectly. The 3rd load started just fine, but then the F11 and Fdl codes showed up. When I hit the "Pause" button to begin restart, restart has already begun. I know this because the relay clicking to lock the door begins immediately, goes 6 times and then the Fdl code showes. When I started the cycle, the door lock worked fine, the door lock light came on, but for some reason during the cycle, about 33 min into a 40 min wash cycle, the door lock light went off and the F11 & Fdl codes come on. When I push the Pause button the clicking of the relay immediately begins without pushing the Restart button. I have an ohm meter and have checked the various door lock switches and they seem fine. These intermitent electrical problems are driving me nuts!! Fortunately I didn't get rid of our old Kenmore toploader of 20 years, and I learned how to open the Whirlpool door.
I have one wire diagram of the CCU but would like to have all the wire diagrams in the machine. Can you give me a link to download these?
When this machine runs it does a beautiful job, so I would like to keep it.
  • DFSmitty66 Feb 13, 2008
    Master_Tech - I checked all of the above as you suggested with the same result. I took the plactic top off of the CCU to tap the K4 relay as it clicked. The first time I did this there was a small flash within the plastic case of the relay, the door locked and the self-analysis started and ran till it reached C07, where it stopped and an F11 code appeared. I don't know if the flashing of contacts within the K4 relay is natural or not. I do know there is a small arc when contacts close, but maybe not as vivid as what I saw. Also, when the F11 code that was the failure of MCU correspondence. I need to check that out more. Thanks for your help.
  • 770 Answers
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Posted on Feb 12, 2008
  • Gary Davd
    Gary Davd Feb 12, 2008
    Any luck with the unit?
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Did 2 loads of wash and tried for the 3rd. Went
sounds like water valve.Try on normal cycle with the hot valve turned off.If no water suspect valve
Dec 21, 2009 | Kenmore Washing Machines
Buttons on the remote of my new undercabinet TV work only on an intermittent basis. I am unable to start at the 2nd or 3rd title of a DVD. Have not yet been able to make the ''Go to'' + ''number keypad''...
My new TV/DVD doesn't work. I went to the indicated GPX website for help, and all I get is a solicitation for a subscription assistance plan. Beautiful: misdirection, subterfuge and confusion. Smoke and mirrors. The new American way.
Nov 12, 2009 | GPX Televison & Video
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Jan 27, 2009 | Neptune MLE2000A Front Load Stacked Washer...
WAsher not working
FL means 'failed to lock' the door didn't lock, so it didn't complete the cycle. Sometimes it's just because the door didn't shut completely or you may have a bad door latch assembly, or worse case, a bad control board. First try unplugging it for 5 minutes, then try starting another load making sure the door is closed completely, if that doesn't help you'll need to open it up to test the door latch.
Jul 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
481 people viewed this question
Dan Webster
Dan Webster
Sal De
