Question about Canon PIXMA iP4000 InkJet Photo Printer
Cyan Not working
On Print Check Pattern, everything prints perfectly, except Cyan (which is 6C) does not print at all. Not even a faded line... Brand new Canon cartridge is in printer. Attempted 3 times. Please help, I've only had this printer for 2 years, and this is the first time ever encountering a problem.
  • John1919 Feb 13, 2008
    I have now done the printer cleaning for printer maintenance 3 times, to no avail. I am wiling to try the cleaning procedure you recommend, except: What is "Spiris"? Thanks,
    Problem Solver:
  • 17 Answers
Use the printers maintanance software to clean the cartridges ( start--settings--printer & faxes, right click your printer icon, choose properties, go to maintanance, click clean in cartidges. Max cleaning attemps is 3 times.
If that does not work, you need to clean the head manually.
Note that this procedure may destroy totaly the head.
Take a small tray and put some water inside (fill the tray to 3mm deep) Add few drops of white spiris in (2-3% max). Put the head inside (the solution must just cover the print nozzles on the head. Leave it there for few hours, then take it out, allow to dry, put it back in the printer, put the inks in, make one cleaning and try again.
If does not work.......you need a new head.
Posted on Feb 12, 2008
  • Adojnis Eliades
    Adojnis Eliades Feb 14, 2008
    sorry, that is white spirit!!!
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Canon i550 not printing any color, Prints in black OK but no color.
Please check nozzle head pattern first. Is your print head pattern printed perfectly?. Be sure that the print head pattern is ok. No missing line or column. If your nozzle colour is not printed at all even just one point,check the print head or try to clean the print head.
e-manualshop
PrinterClinic
Jan 03, 2010 | Canon i850 InkJet Photo Printer
My cyan ink won't print. i have tried EVERYTHING.
The printer cannot use photo inks like Photo Cyan or Photo Magenta. Be sure to use "BCI-6 Cyan" in position 5 - farthest to the right.
Nov 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My magicolor 2350 has cyan print problem
replace the cyan image unit might go a bad one
Oct 04, 2009 | Minolta magicolor 2350 Laser Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Cyan toner problem
Is the section that is not printing down the r/h side of the page?
If so then it is likely that one of your toners is not "locked" in fully. Open the top panel, lift up the orange lever and pull out the PCU. You can now rotate the cartridges, check each one is fully locked in by the coloured levers on the r/h side. Even if one is slightly raised it will block the path of the laser and cause the symptoms that you describe.
Please take a moment to rate this solution. Thanks.
Mar 07, 2009 | Epson Aculaser C1100 Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Only half of the 6c nozzle check pattern working
That issue usually indicates a bad printhead. I had to fix a lot of i9900 printers, and after cleaning the printhead there still was no change. Other models do that too when the printhead starts going out. This is an expensive printhead, but easy to replace, as you know. Link below to some options:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313.TR0.TRC0.H0.Xi9900+printhead.TRS0&_nkw=i9900+printhead&_sacat=0
Jun 09, 2017 | Canon i9900 InkJet Photo Printer
Only Prints in Magenta
The cartridges may still be at fault, or there is a problem with the processor board in the printer. I have also seen problems with the ink jets in these.
Jerry G.
Apr 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
77 people viewed this question
old marine
old marine
