Question about Argus QuickClix 5150 Digital Camera
The Lens I can not get the lens inside of the camera to go down .I think that it is broken.How can I fix this??
  • 13,433 Answers
Hey, bad news for you, the mechanism seems to be jammed, fixing this yourself can be really difficult, I have tryed and failed.
I would recommend takeing the camera to a local electronics or pc repairshop for analysis.
Warranty doesnt cover this problem.
Posted on Feb 12, 2008
When the camera is turned on and the 16-105 DT 3.5-5.6 zoom is attached there is a repeated clicking sound that continues until the camera is turned off. A sony camera salesman indicated it was the lens. ...
I had the same problem with my SAL-16105. It turned out that inside the lens the FOCUS DIFFERENTIAL RING (Artnr.: 321020202) was broken. The camera tries to move the focus from one end to the other when it is turned on (probably to check the functionality), but as the ring is broken, focus will never reach its end-point. Thus the camera continues to try to turn the mechanics futher until either the gear on the lens ring or one of the gears inside the lens will jump, making the clicking sounds. Another reason might be that one of the brushes ("focus brush") inside the lens that are used to signal the position of the focus to the camera electronics is damaged. (This might even lead to the mechanical destruction of the focus differential ring I think). I was able to repair my ring, but as I had to glue it, after a few months it failed again. I'm waiting for a replacement ring now.
May 15, 2011 | Sony 16-105mm f/3.5-5.6 Zoom Lens for ...
My lens fell down and I think is not broken but the front part is separated, can I repair it myself or should I sent it to customer service?
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
Feb 11, 2011 | Canon EF 50mm f/1.8 II Lens
Automatic lens cover does not fully open
1. there's a problem inside of the camera especially the gear if the camera fell down or applying excessive force to the lens part. The gear was broken thats why it was not fully open and having weird noise inside.
2 if you went out to the beach or place a lot of dust.possible the sand or dust goes indide of the lens gear and cause of stuck up and not fully open the lens.sometimes becuase of this the gear was damage or broken and you need to bring to service center.
Jun 03, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My camera was dropped and now there are two little pieces of the inside of the camera inside my lens and it won't zoom. is there a way i can take it apart to try to fix it?
assembly of the lens unit is disterbed,lens operation isnot possible,inside optic rings may be broken,so replace with anew lens unit
Mar 04, 2010 | Fuji FinePix F650 Digital Camera
When looking through the front element there is a loose part or wire visible. Lens does not repond when on the camera.
I think the FPC inside your lens must have broken & needs to be fixed. It is a technical problem & you need technician's help.Go to service center & get it done.thanks for reading.VOTE me if my tip is useful.Happy DIWALI & HAPPY NEW YEAR from INDIA
Oct 22, 2009 | Canon AF EF 100-300mm f/4.5-5.6 USM Lens
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
Broken gear inside lens
send me a email to garyphm@hotmail.com
Jun 21, 2009 | Sigma AF 28-200 Lens
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Tamron 28-300 lens broken off from camera
Hi: The only way to have this lens serviceable is by having a qualified tech repair the lens mount. You can contact the folks at Tamron's service center and ask for an estimate. Good luck: theboyd
Oct 15, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Sep 07, 2006 | Sony DSC-T7 Digital Camera
Argus QuickClix 5150 Digital Camera Logo
141 people viewed this question
Top Argus Cameras Experts
Computer Links
Philip
Level 1 Expert
Are you an Argus Camera Expert? Answer questions, earn points and help others
