Question about Philips Magnavox 13MT143S 13" TV
I need to take the smartlock off
I have a 13" color maganavox tv. When on channel four it say all programs rated pgtv13 are locked. I have to enter a code. I dont have the remote so I brought the universal. I went to magnavox .com they said universal will work. Can't get it to work.
So silly. All I needed was to get a universal remote. I went online to magnovox.com and they gave me the code to use to take the code off. Thanks for contacting me back. My computer has been on the blink. Still not working right.
Queen
Posted on Feb 22, 2008
Anyone know what the code is to get my tv unlocked?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jul 05, 2012 | Philips Magnavox 27MS343S 27" TV
Cant unlock tv because the code 319753 mute is no longer working
Hello
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
I bought a used TV with an existing access code. I don't know the code and some channels are blocked. How do I disable the code? or reset it?
Hello
First disabel the lock and re-enter your own lock code. For this do the following.
OK.
Jan 10, 2011 | Philips Magnavox TS3260C 32" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Tv is lock with smartlock
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Feb 15, 2009 | Televison & Video
Smartlock code
I used the following that I found on a site that compiles v-chip reset solutions:
Philips and Magnavox:
Apr 03, 2008 | Televison & Video
Smartlock code
1.Press MENU to show the on-screen menu. 2. Press VOL+ or VOL- to highlight SET. 3. Press CH+ or CH- to highlight PARENTAL CONTROL. 4. Press VOL+ or VOL- to display the SECRET CODE screen. 5. Press VOL+ (on the remote) and the CH+ button on the front of the TV at the same time. 6. Press the Number buttons to enter a four-digit code. The code will appear on the screen as you enter it. The code "0000" is the default of the TV. If you have not set up a code previously,then "0000" is the code.You cannot use "0000" after you set your own code (unless you reset the code to "0000"). 7. Press MENU to save the code.
Oct 10, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 13MT143S 13" TV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
