posted by marteau on Feb 12, 2008
I would appreciate advice on how to take apart my vacuum cleaner to remove a bolt that I believe is stuck in the motor or belt inside the casing. When the vacuum cleaner is turned there is a loud grinding noise and a burning smell.
Thank you!
Comment by marteau, posted on Feb 12, 2008
The model is a Eureka Bravo II. Please let me know if you need more info.
Thanks!
Thanks!
Clarification Request
by reddevil6, posted on Feb 12, 2008
Would need Brand and model number to be able to help!!
Solution #1
Most Eureka's, there are 2 or 3 screws on the top to remove, then the top cover will come off. If no screws on top. then they are on the bottom. After the top is off, the belt and brush are right there in the open. To get to the motor, that off the 2 screws on the clamp on wach side of the motor, screws that are around the motor housing and then the motor cover should pull off. If the smell is electrical, if could be a bad motor, which sells for around $75 to $90. If the smell is more like rubber, then look at the belt and brush roll. If you need more info, get the model # off of the tag.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Bosch BSA2822 Pro-Parquet Bagged Canister Vacuum
Bosch BSG81313UC Premium Bagged Canister Vacuum
Bosch 3931 Airsweep Wet/Dry Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum
Kenmore 22085 Bagged Canister Vacuum
Kenmore 22313 Bagged Canister Vacuum
Can you Help with these Vacuums problems?
Hoover U5450-900 Windtunnel Supreme Bagged...
dark marks on carpet after...
I am getting dark coloration on... Answer This...
Sharper Image SI570 Steam Wizard Handheld...
Need instructions for the Steam...
Hi - I just got this at a... Answer This...
Repair Service
Find Vacuum Repairman Near You:
