Question about Samsung ML-2510 Laser Printer
Printing Landscape w/Gardenware software
I have a small nursery and use Gardenware softwere to print stock labels. The software is coded to print labels landscape even though the printer settings are portrait. I guess the software overrides the printer settings. However, it doesn't work. Even setting the printer on landscape doesn't work. The software company had this problem with another Samsung printer but it fixed itself when the owner ran a disk scan. Don't know why that would effect anything but when something is miraculously fixed the last thing you did becomes the fixer (fixee?). Anyway, if anyone has an insight, please let me know!
  • cmarlow41 Feb 12, 2008
    I went in and looked at the print settings. When I changed the setting from a left feed to a right feed (these are odd settings in the proprietary software) it fixed the problem even though I was now lying to my printer! Thanks, Wiz.
  • Anonymous Feb 13, 2008
    turn on
    Genius:
  • 3,587 Answers
Hmmm..disk scan? that's a little weird. the reason that a default setting for a printer occurs in propietary software, like Gardenware, is due to that applications settings. You will most likely find a print settings options in the control manager for Gardenware, where you can either set the type of printing(landscape..that's really apropos, eh?) or you can install a selected printer driver. Then you're print manager will make those decisions.
got backup?
Posted on Feb 12, 2008
  • Patrick Michaels
    Patrick Michaels Feb 12, 2008
    coolness..I used to see that a lot with 3D house design software too. Good on ya.
I am trying to print labels on the Konica Minolta bizhub 250 from the bypass tray and my labels are printing in landscape on my label sheet
Its not in the copier. Its on whatever program your printing from. Try playing with the settings. Don't forget, you can use regular paper until you figure out your correct orientations.
Oct 20, 2014 | Konica Minolta bizhub C250 All-In-One...
Zebra 105sl - printer does not print correct size
This sounds like a mismatch between the printer settings in the print driver and the label settings in your label design software.
In the printer driver - printer preferences- set the physical label dimentions.
Also set the printing defaults to the same settings.
In you design program ensure your label size is the same as the printer driver and also you can set the print preferences in the same program, ensure they all match and hey presto it works. But if nt then contact www,lancerlabels.co.uk, they will talk you through the problem on the phone. They will not charge for the advice.
Mar 17, 2013 | Zebra 105SL Thermal Label Printer
C5280 model is printing landscape even though set for portrait
May i know the software you are using to print ? ( eg Word, excel etc ).
It could be an issue with the software settings.
Try printing using a Notepad.
Aug 17, 2012 | HEWLETT-PACKARD PhotoSmart C5280 Printer...
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
What are the specific steps to configure a Z6M printer to print in landscape as opposed to portrait?
Printing in landscape or portrait !
First of all you have to create a portrait page.
When using the label programme select he page and tick the landscape option.
When you print it will do the rotation.
May 24, 2011 | Zebra Z6M Thermal Label Printer
Print command sent from scale indicator
Change driver setting from portrait to landscape in properties/printing preferences/options page and apply setting. Verify by printing a test page. If test page prints correctly and your application still prints in portrait mode you will have to find equinalent settings page within the application
Nov 19, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Sizing and Orientation problem on Zebra 140 Xill
As far as the size it sounds like it might not be using the right resolution these come in either 200 or 300 DPI. Make usre your DPI is set to the same as the printer. If the printer is 300 and the design shows 200 then it will print rather small on the label. Not sure about the other issue.
Mar 17, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Label will print up/down with the letters sideways
The printer will only print the information it receives. The software and the driver is in charge of sending information to the printer, and if something is wrong is because any form configuration options is not correct. Try re-installing the software again or load the default parameters. Also try to design a new format.
Mar 06, 2009 | Zebra Stripe S600 Thermal Label Printer
Print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Oct 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
Samsung ML-2510 Laser Printer Logo
139 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
