Question about Denon DCR-930R
Difference Between Denon In Dash DCR- 930R / 420 / 570
I have a DCR 570 in my work van and I love the radio reception it gets. I get both am ( for my gospel stations ) and fm. My pioneer ,in my car, only gets fm and even then, I only get good reception in the immediate Bay Area. I recently put a cassette tape in my DCR 570 and broke it. The radio still works but I can't use the tape player. I can't find another 570 but I have found a DCR 930R & a DCR 420. They both look the same on line but I don't know what the difference between either three of these decks.
Can you help me?
  • 1,512 Answers
You will that the same tuner module is used across the range, at least when they are part of the same series. The tape transport has probably broken the capstan belt. Not a big deal to replace generally. If you want to know more about it, get back to me here:). A "FixYa" vote would be great for my profile.
Posted on Feb 12, 2008
  • Dan Fiebiger Aug 24, 2011
    Dar Photo King,
    If you still have your Denon DCR-570- Car Stereo faceplate, and if it still fully works, I'll buy it from you.
    Dan Fiebiger
    Portland, Oregon
    fiebiger5@gmail.com
My radio has all the bells and whistles. It is a large square box that an aftermarket radio will not fill. It seems to have no reception at all. when it gets warm it starts to recive but very weakly. ...
A used one will work, you can get the code at the dealer. As for aftermarket radios: standard aftermarket radio size is referred to as 1 din. Your stock stereo is 1.5 din. To install an aftermarket stereo in Amy car requires an install kit, in your case the kit will make up for the size difference by just filling the gap with black plastic. But there are aftermarket stereos that are 1.5 din. They will still require an install kit, but will completely fill the hole in your dash. If you're planning on getting a $99 stereo at a parts store don't bother and just find a stock one. But spend $150 on an aftermarket stereo and you'll be very happy. Good luck.
Mar 06, 2011 | 1998 Oldsmobile Cutlass
Will radio reception be reduced by using a fiber glass antenna vs using a stainless steel antenna for my cb?
Hi, my name is John. As long as your SWR is not over a two, and the antenna are the same length and grounded good, it should be the same end result, no difference.........hope this was very helpful.Rate this solution on the four thumbs-up.......John
May 19, 2010 | Radio Communications
I am trying to install a van radio. When I hook
If it"s an aftermarket radio, orange wires often aren't used, (it's usually for dimming) try it without connecting the orange wire, but be sure not to leave the wire exposed.
Apr 22, 2010 | 2001 Chrysler Voyager
2003 Chrysler Town and Country Van. Radio has a
check antenna connection at rear of radio and window antenna for damage or breaks
Oct 26, 2009 | 2003 Chrysler Town & Country
Denon DRA 345R. no fm reception.
Hi...
What are you using for an antenna?
Also, do you have aluminum siding or aluminum sheet in your house insulation?
Steel roof? Any of those will kill reception.
Mar 23, 2009 | Audio Players & Recorders
Cd input?
I'm afraid it would be a complicated task to tap into the line input on the cd changer connector because the line input only becomes active when a changer is connected, so you would have to connect a device that would talk to the head unit to tell it that a changer was there
Nov 21, 2007 | Denon DCR-670RD
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Radio stations have shushing sound
Cheap table top radio is mono. Your Denon is not getting a good signal so you are hearing noise. You need a better antenna (roof type) or the antenna needs to be moved and aimed in another direction. Try moving it while the station is tuned. You can also switch the Denon to mono and it will reduce the noise at the loss of fidelity.
Sep 02, 2007 | Denon AVR-587
No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Sep 16, 2006 | Denon AVR-1100 Receiver
Car Audio & Video Logo
256 people viewed this question
Top Denon Car Audio & Video Experts
xxxxxx xxx
Are you a Denon Car Audio and Video Expert? Answer questions, earn points and help others
