Question about Philips 42FD9935/17 42 in. Plasma Television
TV doesn't turn on, blinking red light
When I turn the TV on, the green light goes on for about 10 seconds, then I hear a click inside the TV, then the light changes from green to red and then blinks constantly. The picture never shoes up, and the TV stays black. I was watching TV and the TV just turned itself off on it's own and this problem has been occurring ever since.
I have called Phillips customer service and they have been no help and told me to take it to a service center. Before I dish out $500+ dollars to have it fixed, I thought I'd come here to see if anyone else has had this problem before or has a solution.
Thanks in advance.
  • 1 more comment
  • polosprt009 Feb 12, 2008
    This problem occurs right away as soon as the set is turned on. When I turn the TV on, the light in the bottom right hand corner turns green for about 10 seconds, and then continually blinks red until I turn the TV off. This happens every time. I've gone through the manual numerous times and searched the net high and dry for information regarding this matter and have come up empty.
    Thanks in advance for your assistance!
  • Anonymous Dec 25, 2008
    Excuse me, i might be acquiring a tv with the same problem, same model. I have a question,. i was unable to locate ,Replace the board (pt#313815868221) you indicated on the internet anywhere cept here. Is there another name for it possibly the Main power board?
  • ED CARSON
    ED CARSON May 11, 2010
    Does this problem occur after time,or immediately upon turning set on? I will study the service manual on this set after your reply for board or component level part replacement.
    Problem Solver:
  • 10 Answers
I will study the manual and find your problem.I have some similar philips model manuals that should work.I may have yours,but I have to search my database.I will find symptom and solution within a day. - edcarson
Posted on Feb 12, 2008
  • ED CARSON
    ED CARSON Feb 12, 2008
    OK,I looked it up.First I would replace part 1H00 (27mhz crystal) (pt#823827736071) on the SCALER (Viper Control) Board.If that doesn't fix it,Replace the board (pt#313815868221).That should do it.Let me know,edcarson.
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
We have a sony wega KDF e50a10
Over Voltage Protection 03. This is the fault. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Blinking codes to Sony TVs are described in detail.
Nov 12, 2012 | Sony Wega KDF E50A10 TV
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
Jun 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Philips 42FD9935/17 42 in. Plasma Television Logo
724 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
