Question about Canon EOS 400D / Rebel XTi Digital Camera
Flash will not Flash
Even in automatic mode the flash will not flash.
  • 2 more comments
  • mojonaut May 03, 2008
    Hi, yes, I do have the same problem. As you describe, when in green box or any other mode which automatically allows the flask to kick-in, the flash will not pop up, nor can I get it to open by pressing the button under the creative zone modes. Also, when I do manage to get the flash to pop-up, it will still not flash under any of the above modes. Any idea what could be wrong?
    Thanks in advance.
  • jlibler Aug 23, 2008
    I have the same problem. The flash will not pop up in auto mode nor any other mode.
  • Anonymous Feb 06, 2009
    I have the same problem. Has anyone been able to fix their on-camera flash without spending lots of money!?!?
  • Andy May 11, 2010
    I think we need a little more information:
    • Are you referring to the Green Box mode when you refer to 'automatic mode'?
    • If you are in the Green Box mode, does the flash pop up automatically when you are in a dark situation? You can test by leaving the lens cap on and pressing the shutter button half way down.
    • In one of the Creative Zone modes (P, Av, Tv, M), are you able to manually pop the flash up? If so, does it fire when you fully depress the shutter button?
    • Are there any error codes displayed on the camera's display?
Error code e05
Posted on Jun 05, 2008
When my OM-D 10 is in "P" mode the flash fires but the pictures are very, very dark, obviously underexposed. What's wrong?
"P" mode in most digital cameras is, "Program", meaning that it's really kind of manual. Attempting to shoot flash in this mode is likely to be difficult. Suggest "A", or "Automatic" mode.
Oct 31, 2014 | Olympus OM-D E-M10 16.1 Megapixel...
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
Nikon D3100 won't flash
If you have set the main dial to the green camera logo, with automatic in bad light, and the flash still does not pop up, you could start worrying. The mail mode dial is very easy to turn, even without knowing. It happens to me more often than I would like. My next camera must have a special button to lock this dial.
When you chaco the manual, you will see there are settings the flash won't pop up and even when it is up it won't flash, because that menu excludes the flash.
Jan 12, 2014 | Nikon D3100 Digital Camera
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
Flash will not close on Canon EOS 7D
All you need to do is set the camera to shutter priority other non-automatic mode, hold the flash shut and hold the flash button next to the lens opening. You'll hear a motor and a click and it should latch shut.
Jan 30, 2010 | Canon EOS 7D Digital Camera
Flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Jan 20, 2010 | LG KU990 Viewty
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash modes?
There are 5 flash modes: Auto-flash, Manual fill-flash, Auto-flash with red-eye reduction, Manual fill-flash with re-eye reduction, and Flash cancel. In Macro mode, the built-in flash is automatically disabled.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
190 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
