Back to:
Tags:
OKI C5200n Laser Printer
Toner sensor error (by 4 users)
posted by igor99 on Feb 11, 2008
toner sensor error
Comment by igor99, posted on Mar 25, 2008
the toner and drum needed to be replaced. After replacing issue went away!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by psmyt, posted on Jun 12, 2008
Hi. We've just had the same problem with our toner sensor error. However, replaced with a new toner and checked the blue handle, but problem still occurs. Can you please help?
M
Comment by poyan, posted on Apr 14, 2008
!Toner sensor error 543
. Locked levers forward every time same message
Replaced toners x 3 same message
Cleaned LEDs with cloth given in toners same result
Comment by cav utd, posted on Mar 21, 2008
yes i had the same problem on my oki 5600.
2 things to check
1. i changed the belt and the blue buttons on the belt was not locked properly causing the toner sensor error. The problem is now solved.
2. make sure when you replace the toner that the blue handle is locked properly.
Best Solution
Inappropriate (40)
cav utd
Rank:Apprentice Apprentice
Rating: 40%, 1 votes
Have you checked the transfer belt that the blue buttons are locked proply the could have moved when you put the new drum in.
the drum and the toner cartridge were placed into the machine together and the blue handle is locked.
the sensor error happen to me because i replaced the belt and i didn't lock the buttons correctly that solved my sensor error.
Rating Locked! (?) igor99 has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on toner sensor error:
I don't want to Accept this solution
Solution #2
posted on Mar 24, 2008
Inappropriate (40)
tdoles
Rating: 70%, 2 votes
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Thank You!
Can you Help with these Printers problems?
When printing there is no color..I have checked all...
I have tried loading in the bypass try and in the tray and...
Error message 380: Paper Jam shows on display which I...
All lights are flasing on the OKI 3400. There is not...
getting a 356 belt error problem. i installed belt unit...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
