Question about HP Photosmart C6180 All-In-One InkJet Printer
Faxing problems I cannot get the fax working. Everything else works. I have followed the instructions for a dsl router but it still comes up with a "cannot send or recieve faxes" error message.
  • JBDAL Feb 20, 2008
    My fax is set up, the printer works fine (wirelessly), I can send faxes, however, I cannot receive faxes. It continually rings and does not answer. I have it set to auto answer. I can answer it manually and it will capture the fax, just not on auto answer. PLEASE HELP!!
  • 181 Answers
Ok well here are two questions that are both going to get the same answer so here goes. Follow the link and go to the appropriate heading. Fax issues can be caused by so many issues but this is by far the best document I have seen to address them all and is in easy to understand terms. Make sure you check the fax settings just like it says and if still having issues please post again with the steps you have tried and what happened so that someone here can tackle that issue specifically. Please read and follow this first - works almost every time.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=1153494&dlc=en&lang=en
Posted on Feb 28, 2008
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
I have a Dell 966 AIO printer. All of the functions of the printer are working correctly, however, many of the phones in my home have ceased ringing. All are live and calls can be placed and received,...
Setup should look like...
Wall > ISP Modem/Router > Wireless router(if any) > Wired/wireless
If using DSL, a DSL Filter MUST be on ALL devices, phone, answering machine, faxes, etc..., everything EXCEPT the DSL Modem/Router.
You may share a DSL Filter.
Wall > DSL Filter > Splitter > Multiple Devices
RFick
Jun 11, 2011 | Dell 966 All-In-One InkJet Printer
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
I lose PC's internet connection when faxing with MX860 on network
Yeah look like you have dsl and in that case you need a filter to go on that line so it will filter out you dsl connection so the data will pass threw.
I has two plugs one for you dsl modem and one for you fax or voice...
if you have one of these make sure there on all lines even the fax line, if you do have one then it needs to be changed out as it is bad.
Thanks please do not forget to rate my answer and leave feedback
May 13, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Won't fax -printer message is "will dial soon"
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Feb 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Can't send/receive fax
Jan 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Error 20 01 NG: poor line condition on outgoing fax's
My fax shows poor line condition. I have checked all of the connections and everything is ok. Perhaps my settings are wrong
Jan 23, 2009 | Brother IntelliFAX 4100 Laser Fax
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
HP Photosmart C6180 All-In-One InkJet Printer Logo
265 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
