Question about Hotpoint Ultima WF860 Front Load Washer
Squeaky spin machine squeaking when spinning but not during wash programe
  • 4,102 Answers
Hi this is going to be one of two problems one is cheap and easy the other expensive and hard to do unless you have special tools.
first i give you cheap and easy problem this could be that the belt from the drum to the motor is slipping under the pressure of the spin cycle these are cheap to buy and only take ten min to fit thats if that is the problem.
The second problem is expensive and hard to do unless you know what you are doing this problem is the bearing on the drum this problem is best getting solved asap as if left will damage drum and usually the motor it damages them as it seizes in the drum causing the motor to over heat and can cause a fire.
If you open the door and turn the drum by hand see if you can hear the noise and also check to see if it turns smoothly it wont be really easy to turn but should feels smooth.
If this is fine then you are lucky and will find that the belt needs replacing my even need adjusting as some you can adjust like a fan belt on a car hopefully you know what im going on about if not contact your local repair shop and they should get you the part for you and tell you if it can be adjusted.
Let me know if you need further assistance ok
Posted on Feb 12, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Squeaking/grinding/rattle noise during wash and spin
That sounds like a clutch problem - probably just worn and need replacement. Will definitely need to pull to find exact fault.
Regards
Nov 16, 2008 | Washing Machines
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Jan 11, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
157 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
