ProScan PSVR70 VCR
I recently switched to DirectTV and now I can't record on my VCR. I know it is working, because I recorded the channel I had on the TV. DirectTV said I should have both the TV & VCR on the same input, like Video 1 & L1. I did this and then went to Guide on TV selected a program and went to "autotune." Then I programmed the VCR for the same thing, and nothing happened. All I got was a snowy screen. Hope you can help me.
  • 979 Answers
Sounds like the VCR is not set on an "external source" but rather "tuner". I believe that will fix this problem...accordianman
Posted on Feb 15, 2008
How do I stop my ProScan VCR from recording?
I need more information, but if you find you are accidentally recording over tapes that you never want to record over, break off the record tab on the cassette itself.
If you do ever need to record over a tape with the record tab broken off, simply place tape over the tab hole.
If you don't mind voiding the warranty, you can install a record safety switch either in series or parallel (depending on the sensor type) with the record tab sensor inside the VCR, or in series with the record button itself.
Hide the switch in the back of the unit so nobody finds it.
Feb 24, 2011 | Proscan Televison & Video
How to record a radio station on the TV onto a vcr tape
your better off getin a digital recorder like
http://www.amazon.com/Olympus-WS-100-Digital-Recorder-Interface/dp/B0009N9PJA
pros u can index spots of the show
May 21, 2009 | Proscan PSVR65 VHS VCR
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
VCR will not record with new digital cable box
The short and simple solution is to tune the VCR to the channel that the cable box is set to (4), and then tune teh TV to the VCR's output channel (3). If you do this you should be able to see the Cable channel through the VCR tuner and then record. Any other solution would require figuring out how to set both the VCR and the cable box to the same channel, but it sounds as if you have ruled out any possibility of being able to do that.
Feb 18, 2009 | Emerson EWV403 VHS VCR
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Recording to DVD recorder
I know you can copy to the VCR. but do not know if digital recording has any form of copyright protection. You can try to copy by connecting the outputs of the DVD TV to the inputs of the DVD player recorder.
Jul 24, 2008 | LG RC199H DVD Recorder/VCR
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Vcr timed recordings
I'd be pretty certain that every VCR made these days (and of the last 10-15+ years) can be set to do a timed recording. They can be set for a one time recording, weekly or daily record. Whether used with a cable/satellite box, or outside antenna, you must ensure proper hookup. I'm not real familiar with recent cable/sat receiver boxes, but older ones had to be set to the channel you wanted to record, as the VCR will only see that channel. On older cable (no cable box) & outdoor antenna systems, a VCR could tune in and record any channel, while you watched another one. Anyway, check the capability of the cable/sat box, and follow suggested hookup. You will likely need to set the box to the channel you want to record before you retire for the night.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
