Question about Maytag Atlantis MDG7400AW Gas Dryer
How do I troubleshoot drying problems ?
The vent is clear, the unit just isn't drying ! The unit is only 3 years old. I am a electrician so I can look at the parts. I can't get the clips off the bottom to open the unit up !
  • 3 more comments
  • I_have_Issue Aug 14, 2008
    I have the front of the dryer off, I can smell gas, I see the ignighter light up, but the flame doesn't start. Is there an adjustment? It worked perfectly for 3 years, then this. Can anyone help?
  • atong929 Jan 12, 2009
    Our five year old dyer doesn't heat up. We checked the vents and it is lint free. I can't open the bottom of the dryer.
  • cdefeo53 Feb 05, 2009
    The ignitor glows, the burner lights, but only for about 10 to 12 seconds. The drum continues to spin. After about a minute the process repeats. At this rate the clothes never dry. I replaced the thermostat on the pipe just above the burner, but that didn't fix it.
  • dhlms12 Feb 14, 2009
    The ignitor glows, the burner lights, but only for about 10 to 12 seconds. The drum continues to spin. After about a minute the process repeats. At this rate the clothes never dry. dhlms12
  • dhlms12 May 11, 2010
    It must be a maytag
Most likely, it is the flame sensor.
This is mounter above the burner, it is round and has 2 wires and 2 screws holding it in place.
Clean it, or replace it.
Posted on Jul 22, 2009
Check the heating element. it is a wire that heats up in the unit that gives you heat. about 15or 20 bucks
Posted on Apr 22, 2008
Haved a problem with a Maytag  gas dryer it is a model  MDG9806AWW The problem it does not heat up. It runs , blows, but does not ignite to heat up.  Do you have a easy solution.
Posted on Dec 03, 2008
  • James Striker Dec 03, 2008
    My Maytag Gas Dryer  Model No. MDG9806AWW does not heat up. It runs the fan, but it does not sound the ignition when this turns the heat. Can you help , is this an easy fix
Could possibly be thermostats or heater if its just blowing cold air
Posted on Feb 12, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Dryer vent was partially obstructed. Cleared out vent, but now the dryer will not heat up on any heat selection. Dryer operates, but just not heating up at all. The appliance is about 3 years old. I...
You have either shorted the breaker or broken the coil. If you check the breaker first, save time. If that isn't it, and you need to replace the coil, be careful that you don't short the coil against the machine itself or you will end up in the same boat.
Good Luck
Joe
Aug 29, 2011 | Dryers
We have a LG dryer that is about 2-3 years old. The sensor is completely lit showing an obstruction but we have cleaned the vents out all the way to the roof and the sensor stays fully lit. The clothes...
Check the exhaust vent behind the dryer to make sure it's not kinked.
Take off the dryer vent and run the unit to see if it will dry normally. If it does, you still have a blockage in your exhaust vent in the wall.
Jul 20, 2011 | LG DLE2532W Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Hi, my stackable frigidare dryer isn't doing a very good job drying my clothes. The unit is about 3-4 years old, but has only been used for 2 years.
Make sure the vent is completely clear and the air blowing out is a pretty strong flow. It could be a defective thermostat too. Another reason is sometimes the washer doesn't spin the clothes out enough and they are too wet to dry normally.
Jan 06, 2010 | Frigidaire Dryers
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Maytag Atlantis MDG7400AW Gas Dryer Logo
391 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
