Question about Microsoft Zune JS8-00001 Digital Media Player
Not charging When I plug it into either the wall unit or the computer, there is no connection at all. It will not even charge. Any suggestions? Do I need a new piece put in? Do you know how much that would cost?
  • Anonymous Feb 28, 2008
    I ve only had my zune for les than two months and it would not charge or zune software did not reconize I had plug zune in. This website helped. As soon as I clicked on Fixya, my zune started working. Thank you for this website because had a hard time finding on zune official website. Why does the zune do this? Is because I let battery to low?
Yeah i'm actually having the same problem..I'm sitting in class trying to listen to some Wyclef Jean and the lil' 13astard won't charge
Posted on Feb 15, 2008
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
MY GPS MAGELLAN IS SHOWING LOW BATTRIE, WHAT DO I DO TO FIX IT.
You should have received either an AC adapter or a USB cable with the unit to use for recharging your battery. The AC adapter would just plug into the wall socket and then into your unit. The USB cable would be connected to your computer while it was running and then the other end would fit the GPS. This will also charge your unit. If you do not have either of these cables you should be able to go to your local Best Buy, Circuit City, or even a Walmart, and you will be able to purchase at least a USB cable that will charge your unit. There are adapters out now that will plug into the wall and then plug into the USB port on the GPS for charging purposes.
May 15, 2011 | GPS
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
605 wifi won't start
I was having a similar problem where my 160 gb Archos 605 would not hold a charge even after two days of being plugged in through an AC wall adapter. It worked fine for 5 months without a problem, but then all of the sudden it would not hold a charge even if the LED light was blinking green.
One thing that I found that makes it now hold a charge now is by letting is by plugging it in to a computer. I don't know why, but for some reason, now when I charge it through a computer usb as opposed to the wall adapter, it charges and holds a chrage for over 3 hours. So, maybe try to just let the thing charge through a computer.
Aug 10, 2008 | Archos 605 Digital Media Player
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
SPS1 charging system
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!) Good luck with it. H.
Jul 30, 2007 | Scott SPS1 System
Microsoft Zune JS8-00001 Digital Media Player Logo
81 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
lugnuts1
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
