Question about Dryers
Dryer stops shortly after being started
After turning my dryer on it cuts out after less than a minute and the PAU light blinks.  It will go on again but will do the same thing.
  • Gary Davd
    Gary Davd May 11, 2010
    post model#
Dust has gathered around the thermostar wtich tells the machine when the cloathes are dry Remove the dust The thermostst is located inside the door on the right hand side it looks like a small nail sticking out
Posted on Feb 20, 2008
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 05, 2012 | Dryers
Runs for little while then stops and has the code PAU on the display. I tried unplugging the cord, I reset the circuit breaker. Still the same and now it won't even start.
Try taking the control board out and check for burned off traces. Solder back those points and it should work again. Just did it to mine and now it runs again. Still flashes PAU though.
Jul 07, 2011 | Kenmore 84072 Electric Dryer
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Dont know how to reset or bypass gm theft system car is not starting .It tries and quits.
this is one way to reset it :
first make sure the battery is fully charged , then do the following:
key in the ignition but do not crank the motor, just leave it at the
ignition mode for ten minutes ,then turn it off POSITION for 5 seconds then REPEAT again 2 more times. at the 3 rd time youre gonna notice the ANTI THEFT light on dash to blink. when doing the last step , remove key , inserted again and turn on motor , good luck , AJ
May 28, 2009 | 2001 Chevrolet Malibu
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Dryer starts to work and then stops working after a few minutes
doesn't usually happen so quick but may be a blockage in the air duct. take top off. if i remember right, duct runs across the back to the dryer fan. check for lint build-up. if poor air flow, an overheat stat will cut off the dryer
Apr 02, 2007 | Indesit WA 125 Front Load Washer
Dryers Logo
73 people viewed this question
Top Dryers Experts
Marvin
Marvin
