Question about Panasonic KX-FM220 Plain Paper Thermal Fax
Fax film pulls through with copies
After printing a few copies the fax film gets drawn into/along with the copy being made. Ultimately the fax film tears. I cleaned the unit thouroughly, this seemed to help a little. I phoned Panasonic, they suggested it is a timing problem with the gears on the fax film cartridge. How do I set this?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Timing is usually associated with a motor, try and see if the motor can be dismanteld, clean with alcohol and put oil on finger to lube inside.
If not then motor needs to be changed.
Posted on Feb 14, 2008
Can't send and receive a email
You have to fax email copy it then fax. and the same the other way print it to paper and send it. It's a fax machineIf you have 4 in one then you can have a email address just for your machine
Mar 11, 2014 | Panasonic KX-FB421 Plain Paper Film Fax
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
4100 when I copy I get a black line down the middle Ok after cleaning inside top cover, but,comes back after a few copies. Printing and sending fax ok.
Try printing out a report. If the line is still there you need to use the wire cleaner on your print cartridge or if that doesn't work, replace the drum unit.
Apr 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Bad copies on our Canon ir2200
Most likely the fixing film needs to be replaced. A few years ago Canon made the fixing films available to authorized dealers.The film itself should only cost a few dollars.The other thing might be the Drum unit itself.They are not so cheap.Independent dealers and service agents are generally cheaper than say, Ikon or Danka
Mar 26, 2009 | Office Equipment & Supplies
Brother Intelli755 fax lost manuel. . .when I push copy, nothins
HELLO JUDIE! YOU CAN DOWN LOAD A MANUAL & BROTHER .COM. AS FOR THE LINE IT SEEMS TO BE COMIMNG FROM THE FILM CARTRIDGE , THAT IS ALSO THE PRINT CARTRIDGE ON THAT MACHINE. ARE YOU USING REFILLS? OR BROTHERS OWN , CHECL THE CART. GOOD LUCK BROTHER SR TECH
Jan 31, 2009 | Brother FAX-575 Plain Paper Thermal
The fax will not print anything
2 possibilities
1- you did not remove the plastic film on the cartridge
2- the printhead has dried up
Dec 04, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Panasonic KX-FM220 Plain Paper Thermal Fax Logo
69 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
