Question about Denon AVR-1907 Receiver
Sub Problem with Dennonavr- 1907
I have the avr- 1907 and I have bought a infinity Sw-12 I can not get the sub to work, I have made sure the cable is hooked up to the sub out port. If any ideas please email me at acebuddy2000@yahoo.com with Sub issue in the title.
Thanks Nate
  • surfblue22 Jun 14, 2008
    That still did not work, I ahve now had this Sub for 6 monthes and I still cant get it to work,,,, Dennon needs a MUCH MUCH easier setup.
  • fab2871 Dec 27, 2008
    Tried everything I can do with the sub, but it still won't work. Thought I had a quality product.
    Scholar:
  • 67 Answers
Go into setup and make sure sub is turned on and set sub for LFE + main otherwise sub will only work with Dolby Digital LFE signals. LFE plus main setting will allow sub to output low freq's that would normally go to Front Speakers. Refer to Owners manual setup Info.
Posted on Feb 12, 2008
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
When I Connect the LFE Output of the Amp to the LFE Terminal of SW, the SW does not work, however, if the speaker output of Amp is connected to SW, it works ok.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Infinity-PS-12-Subwoofers-manual/id/21470dj882/t/2/
I'm assuming your amp for testing was NOT a subwoofer output. I could be wrong.
Your source is responsible for creating LFE output. Are you sure it's doing that?
Tune an FM station and connect any other active RCA output from the source (like a Tape Out) to the sub
Mar 05, 2011 | Infinity PS-12 Subwoofer
I have an AVR 4806 I have a powered sub plugged into the SW but no sound coming out of the sub. The other speakers are working but just not the sub. Is there a setting that I am not seeing?
is it plugged into the sub-in or sub-out. if all else fails just plugg your sub into the audio out somewhere on the bk and youll be fine.
Jan 31, 2011 | Denon AVR-4806 Receiver
Can i hook up two subwoofers to a denon avr 1907
Sure, just get an RCA splitter and share the Sub Pre-Out with the two self-powered subs or one amp powering two of them.
http://www.retrevo.com/support/Denon-AVR-1907-Receivers-manual/id/696ci072/t/2/
Dec 28, 2010 | Denon AVR-1907 Receiver
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Danon avr 3200 subwoofer
LOOK ROUND THE BACK OF YOUR AMP AND YOU WILL SEE A SOCKET MARKED SUB PRE OUT.PLUG YOUR SUB CABLE INTO THIS AND THEN TO YOUR SUB.MAKE SURE YOU DO NOT PLUG INTO THE 6 CHANNEL IN AS YOU WILL GET NO SOUND.
HOPE THIS HELPS.
May 31, 2008 | Denon AVR-3200 Receiver
Denon AVR-1907 Receiver Logo
256 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
