Question about Denon DN-C615 CD Player
DENON DN-C615 DISPLAYS "SERVO ON"
MY DENON CD PLAYER MODEL DN-C615 DISPLAYS "SERVO ON" AND WILL NOT PLAY MY CDS OR ALLOW THE FUNCTION OF ANY OTHER BUTTONS. CAN ANYONE PLEASE HELP ME OUT?
JASON
  • 1 more comment
  • JS1220 Feb 13, 2008
    I have no idea how to turn it off.
  • JS1220 Feb 14, 2008
    Thanks alot for your time and help w/this issue. Look forward to hearing from you soon.
  • Anonymous Mar 14, 2014
    On DENON DN 2100F one CD player plays only the 1st track, but track 2 & above don't play & no data on display. Tried other CDs & same problem.
  • 1,512 Answers
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
  • Graeme Ross
    Graeme Ross Feb 13, 2008
    whoops... that link should have read
    for the manual. I will go and read it a little more and see if I can assist you.
    regards
    Graeme
  • Graeme Ross
    Graeme Ross Feb 16, 2008
    Hi again, sorry, long time between keystrokes my end :)
    Having now read more of the manual, the unit has additional an array of preset features that allow for great control of the units functions. Sleep functions when turned on seem to the state of the servo. Although generally this is to shut the unit down after a preset time of operation. Try disconnecting the unit from the mains, and leave disconnected to power down completely for half a day, then fire it up again and see if the functionality of the player returns. Let me know what happens here. :)
What is a toc problem
TOC stands for Table Of Contents. It is the beginning track on the inside of a CD and tells the player how many tracks there are, how long they are and when and where they end. If a player cannot read this information, it cannot read the CD.
May 13, 2014 | Denon DN-C615 CD Player
Denon troubleshooting
sound like you have changed your burning format and your player does not support that format trying using a different format to burn your songs your player should say what formats it supports like wmp mp3 ect good luck
May 03, 2014 | Audio Players & Recorders
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
We are having a problem trying to record our church services on our denon c550r.what is the procedure before doing rec,play,stop ,finalize?
Place a blank CD-R into the tray on the right side and allow the DN-C550R recognize it as a blank cd and prepare it for recording. Now you can record. Is that what you're looking for?
Dec 06, 2010 | Denon DN-C550R 2-Disc CD Recorder
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Wont read some discs
People need to learn to leave more info if they want proper help!
What type of discs? You say some, are they CD-R, CD-RW, SACD, CD+R, CD+RW, standard store bought Audio CD?
When copying audio cds for playback in other players, always use CD-R to avoid any type of confilcts. CD-R will play in almost any CD player, even from the 80s. Some players say they will support CD-RW, but that is NOT GUARANTEED!
If it is Audio CDs, then the laser may be dirty. If it is MP3 cds or DATA cds, then try only putting one type of file on the disc, such as only MP3s, or only WMAs.
Oct 01, 2009 | Denon DN-S3000 Turntable
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Switch bwtn CONT or SINGLE play on Denon's DN-C615
Try this:
1. While holding "Title", Press Stop to enter what Denon calls "presetting" mode.
2. Press Track Search Reverse or Track Search Forward until you get to 20, which is the presetting mode for Single/Continuous Play.
3. Press Play to toggle between Continuous and Single Play.
4. Press Stop to exit Presetting Mode.
Hope this works! I just finished a belabored job without Single Play on this unit. I have been searching for the answer too. I don't have access to the deck to try it, but I think this will do the job.
Dec 23, 2008 | Denon DN-C615 CD Player
Denon DN-C615 CD Player Logo
735 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
