Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Self-propelled windtunnel bagless
My vacuum is three months old and it is picking up debris but it is not going into the dirt cup it is clogging up in the hole and spitting it back out. the dirt light is not coming on it just stays lit up on the clean light.
    President:
  • 1,673 Answers
Either the inlet down by the brush roll is clogged, or the hose is clogged. Check that out and if you still have a problem, then take it to a warranty repair shop, you have a 1 year warranty on this. Take your sales slip as proof of purchase.
Posted on Feb 12, 2008
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
My self-propelled windtunnel bagless hoover does not pick up.
Remove the dirt cup.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Feb 21, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Suction
absolutely all the air in a vacuum would pass through the filter and if its clogged badly you could loose all your suction and if the belt is more than a year old then replace it even if it isnt broken ( they stretch out over time )
Sep 17, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Loss of suction in my Hoover Windtunnel bagless selfpropelled upright
Did you check the dirt inlet by the brush roll, filters ok, they should be replaced once a year. Belts can look fine, but if they are a few months old, I am sure they have stretched and the brush roll will not turn like it should under load. It is possible that the motor isn't running up to speed, thereby reducing suction.
Mar 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
220 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
