Question about Samsung SyncMaster 213 T 21.3" LCD Monitor
SAMSUNG CW21Z573 Slimfit TV (small CRT)
I am unable to play my MP3 player thro the audio inputs on the side of the TV (red + white).I can only get the MP 3 to play by connecting a DVD to Ext 2 ,is there anyway i can i just play the MP3 by plugging into the audio onputs.
ctf1800
  • 4402 Answers
SOURCE: Pink and white lines when I switch input to DVD player
Sounds like engine lamp is bad
Posted on Jan 24, 2008
jitenok
  • 151 Answers
SOURCE: monitor
Check relay in power section for fault.To degaus the monitor.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 08, 2008
SOURCE: I bougth a lcd samsung 40 inch tv. I cannot connect my gamecube
You need to get a special scart lead which you can connect your red, white and yellow leads to then connect the scart lead to your tv it should work then
Posted on Feb 01, 2009
  • 54 Answers
SOURCE: Black and White Video input
Check your plug that plug into computer, one of the legs has bend.
  • 81 Answers
SOURCE: on right side of my monitor 2 ,3 verticla lines or blinking.
That sounds more like a graphic card problem than a monitor one. try conecting your pc to a different monitor and see if the problem persist.
Good luck
Posted on Mar 03, 2009
I have a Veon TV/DVD . I want to hook it up to a Samsung VCR/DVD player . if I want to play a video what channel on the veon TV do I play it on. Or is there something I am doing wrong Julie
Hi if U r using 3 RCA cables RED WHITE ,& YELLOW connect them to the input sockets on TV red is audio & white is audio yellow is picture then set the TV to AV .. INPUT.cheers
May 14, 2016 | Samsung Televison & Video
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
No sound from xbox to stereo using an optical out from TV to amp
If Im reading this right what you need to do
is hook the audio from the xbox to the stereo system
not to the tv .
Apr 04, 2009 | Samsung SlimFit TX-S2783 TV
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
How do i get my sansa e250 to conncet to my tv
Plug a 1-to-2 audio jack from the headphone jack of the Sansa to two audio inputs (red and white) of the TV. Change your TV's source channel to the appropriate input (AV1, AV2, Video 1, Video 2, etc). Find the song on your Sansa and press play. you may have to adjust the volume on the Sansa AND on your TV.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
I have no sound from my samsung tv to Samsung HT-TZ315R/XEU i have connected with hdmi and the white and red plugs i have sound from the dvd player but not the tv any suggestions
Make sure the red & white connectors you are using on the TV are actually audio out, and not audio in. If you are using the connectors on the side of the tv (adjacent to the yellow connector), then these are inputs.
If your TV has no audio out connectors, then if you have a European TV, you can use one of the scart connectors with an adaptor.
Also, check the red & white connectors you are using on the home theatre system are inputs. Also check the source is set correctly.
May 16, 2008 | Samsung Televison & Video
How to connect dvd
if you use the standard red white and yellow connections from the back of your dvd player to the back of the tv on the in portion it will work. just make sure the tv source is selected as AV1
Apr 06, 2008 | Samsung SlimFit TX-S2783 TV
Samsung SyncMaster 213 T 21.3" LCD Monitor Logo
309 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
