Question about Dishwashers
Dishwasher heating element
How do you remeove the heating elemrnt in the baumatic bdw2ss? Does it just pull out or is there a fixing underneath?
  • 54 Answers
Its got a nut under neath.
Posted on Feb 12, 2008
Water not hot cold on baumatic BDI630 - ELEMENT ONLY WORKS WITH FILTERS OFF
no I get copy of engineer in to checked the problem but not solve. they said to get how of the company maybe you guy would no the problem
Oct 03, 2013 | Baumatic 23 in. BDW13 Built-in Dishwasher
Detergent tablet doesnt disolve fully after a cycle
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Baumatic Dishwashers
Hi every time i turn on my baumatic dishwasher it tripps the main rcd
if the heating element is okay then the motor is going bad...
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 21, 2010 | Baumatic Dishwashers
No heat all other functions seem to work
Either the elemrnt or there is a thermistor on or near the element hosing.
At the back, unplug and disassemble elemrnt casing, when free from yhe unit.. inspect element. if ok.. then a silver dollare size item on the casing need replacing.
Put an Ohm meter accross this thermistor and see if it is open (1) on the scale
replace it, put it back together. Happy Drying
Jul 25, 2010 | Whirlpool LEQ9030P Dryer
Dishwasher door wont open. Broken handle latch?
I have the same issue, did you get an answer ? Save the plates !
regards
Andy
Apr 26, 2010 | Dishwashers
What is the error message E3 ?
The E3 message on your Baumatic dishwasher is a malfunction of the temp sensor or the heating element. Test each part separately and replace the faulty part.
Dec 21, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hello I am getting error code E3 on my Baumatic dishwahser- how may I resolve this? Thank you
its "malfunction of temp sensor or heating element"so it is either the heating element or temp senser.is faulty test and replace the faulty part
Nov 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Water is not heating in dishwasher
On the BDW13 Baumatic dishwasher I had the same problem, as I fix gas boilers I ohm tested the heating element, which was ok, I then tipped the machine on its side and took the bottom off, be careful, always disconnect the electric and water, underneath there are two thermostats, I know them as thermistors on a boiler, they screw into the brackets that hold the element in place inside the dishwasher, I unscrewed them after removing the wire connectors(pull off) I then ohm tested them and found one was an open circuit(faulty) the problem is, the one that was faulty is a non-self-resetting type, which means it has to be replaced once it has tripped, which is a real pain, the other one resets after it has cooled down.
Aug 18, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
E3 - Non Release of Tablet
The E3 code means - Longer heating time.Not reaching required temp. Cause - Malfunction of temp. sensor or heating element. Good luck !
May 10, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
