Question about Motorola Mobility RAZR V3i Cellular Phone
Battery problem Even when fully charged it only last for couple of hours before is depleted.
    Brigadier General:
  • 7,752 Answers
It is not a problem with the phone the battery just needs to be changed.
Posted on Feb 11, 2008
Camera will not come on. I bought new battery for it and still nothing
As long as the battery is fully charged, if it doesn't work, the only solution is to return it to the maker for repair.
With items like this, the battery depletes over time itself even if it isn't used. I have some very good rechargeable batteries that will deplete in my camera if left for 3 months.
Sep 23, 2016 | Video Cameras
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
I have a Rascal 305. How long should built-in charger run to fully charge batteries. Mine only charges about one hour at 3.5 amps (on meter on back) before shutting off. What should charging current be,...
moleman If the batteries are fully depleted then the on-board charger will not pick them up and charge them to full strength. It is not designed to charge very low batteries. If the batteries stayed fully depleted for a period of time you will have to replace both of them. You should never fully discharge your batteries. The battery level gauge on your chair should be used to determine when to charge if it is the red recharge overnite. Get into the habit of recharging overnite if you use the chair daily. Always store the chair fully charged and if not used weekly charge once a week. Never leave the charged plugged in more than 18 hours. The chair only operates on about a 5-6 volt range from about 21-26 volts. If you are in the red the voltage is down to about 20-21 volts. Hope this helps you
Sep 29, 2010 | Health & Beauty
Battery depleting way to fast
first check that your blue tooth is on ..2nd if you have bought a new battery the charged it at least for 7 hour.
Jun 15, 2010 | Samsung SGH-S5230 Cell Phone
How long should my battery last? I bought an nintendo DS lite and I forgot to ask?
Hello there, the Nintendo DS Lite has four levels of brightness. The battery will last 15-19 hours on the lowest settings, and 5-8 hours on the brightest.This can also vary depending on the type of game activity."
So the DS should last the whole time in even on the highest brightness settings, if fully charged. Nintendo states that it takes 3 hours to fully charge the DS.
hope this helped, also this site will also help you to get your ds battery to last for longer
 http://www.ehow.com/how_2015000_extend-b…
good luck
Apr 21, 2010 | Nintendo DS Lite
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl roseden@telus.net
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
LG VX5400 cell phone power problem
try replacing your battery
Jul 29, 2008 | Cell Phones
Battery
The battery on this model tends to last between 2 to 4 hrs dependant on use. Does yours only work uoto about 2 hrs or does it sometimes last longer? If the battery is more tham 5 years old it MAY be worth changing.
Jun 19, 2008 | HP Compaq nx6110 Notebook
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Battery life cut down to 7 hours
The thing is, you recharge it too much. Because when you recharge it even though it still has battery power left, it tries to recharge it as much as if the battery was depleted. So, your battery overheats, therefore allowing you 7 hours instead of 20. And yes, it is possible to switch the battery.
Apr 12, 2007 | Samsung YP-T8 Digital Media Player
Motorola Mobility RAZR V3i Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
