Question about Dishwashers
TV static I just installed a new dishwasher. When it is running, it causes static lines on the TV. Prior to the new dish washer, I did not have this problem. It is wired correctley, and not on the same circuit. As I stated I did not have this problem until the new dishwasher. I called the service people for the dishwasher, and they stated they could not help me. Have you got any ideas, or do they make some type of filter I can put on the line to the TV.
  • Handyman0 Feb 13, 2008
    To: Tulula, Do you know where to get a plug in suppressor for the dishwasher , or what to ask for unless (suppressor). I have talked to several service people, and they say they can not help me. Thank You.
  • 54 Answers
There should be a suppressor fitted to the mains terminal block on most dishwashers. if this is not the case you will have to get hold of one you plug in. regards
Posted on Feb 12, 2008
  • daniel gooch Feb 13, 2008
    i would guess an electrical wholesaler. sorry i can not help any more than this.
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
The glassware is not being cleaned well. It is often covered in dried food particles - especially if the dishes are not totally rinsed off prior to running the dishwasher. It was much better at cleaning...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 23, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
After running our dishes through a wash cycle we noticed there was still a lot of food stuck on the plates & glasses etc. We cleaned out the trap but due to the murky water in the well, we also pulled...
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
Dishwasher
How to Buy
heatman101
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
My stainless steel dishwasher smells
You need to check to see if the drain line runs from the dishwasher pump to either a "T" on your kitchen sink drain or if it connects directly to the garbage disposal. Either connection is okay. However, water can run downhill from either connection to your dishwasher. To prevent dirty water from your sink or garbage disposal from running downhill to the dishwasher, you may have to install a dishwasher air gap. This can be purchased at a appliance parts store or a home improvement store like a Home Depot or Lowes. It is a "Y" shaped device that should be installed above the dishwasher drain line connection under the sink. As water will not run up hill, you need to make sure that the Air Gap is installed higher than the drain line's connection under the sink. "The Air Gap device should be mounted as high as you can under the sink."
Aug 22, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Feb 13, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwasher
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
