Question about Motorola Mobility RAZR V3i Cellular Phone
PHONE WILL NOT VIBRATE IN THE VIBRATE ONLY MODE. ALL OTHER VIBRATE MODES WORK OK.
  • Anonymous Mar 30, 2008
    i want to make my incoming text messages vibrate but i cant seem were to find the settings for the message alerts. i have went threw every menu on my phone. I can change my incoming calls and other things but not text messaging
    Brigadier General:
  • 7,752 Answers
Try resetting the phone or changing the vibrator
Posted on Feb 11, 2008
The vibrate mode on my phone will not work
Go to phone app, dial the following number-
*#0*#
You will get a screen with following options (Not All)
Click on Vibrations as shown above. If the phone vibrates, then there is some issue with Settings or Software. Restart or Reset should help you. Of it doesn't vibrates, time to visit the service center.
How to Fix Vibrate not working on my phone
Good Luck :)
Sours- How to Fix Vibrate not working on my phone
Feb 20, 2016 | Samsung Galaxy S6 Edge
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Hi, I have a samsung cell phone R450 that says silent mode activated and I don't know how to disactivated can you help me please?
Silence the tones your keypad makes when you press a key.
To enter Silent Mode:
In standby mode, press and hold . # button,“Entering Silent Mode” briefly appears in the display and your phone returns to standby mode
To exit Silent Mode:
While in Silent mode and standby mode, press and hold # button “Exit Silent Mode” briefly appears in the display and your phone returns to standby mode.
Adjust the Ringer:
1. In standby mode, press the volume key on the right side of the phone up or down. Options are:
Ringer Off
Vibrate
Low
Low/Medium
Medium
Medium/High
High
Vibrate/High
2. When you are satisfied with the setting, press OK.Your phone returns to standby mode.
Thank You
Aug 17, 2010 | Cell Phones
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Motorolla Razer V3i Keypad is not working
sir it is hardware problem because of vibration it damaged
Jun 02, 2009 | Motorola Mobility RAZR V3
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
No Vibrate
Go to menu, tools, sound settings, call sounds, then click on call vibrate. click on. click ok.
Sep 08, 2007 | LG VX8300 Cellular Phone
Samsung d900
To place the handset in silent / vibrate mode follow the steps below: To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode. The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
Aug 23, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
103 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
