Question about Sony PlayStation 2 (PS2) Compact System Shelf System
Ps2 slim lid problem
My lid has a broken prong that goes down to cause the brake to move out of the way . this is a like new unit what can i do i cant find a receipt to return it
How can i install hard disc drive into a slim type?
Posted on Mar 01, 2008
The cycle doesn't advance prior to the rinse cycle, unless I bang the lid down. Sometimes takes a few trys then it starts up again and finishes out the cycle. Is my timer going out? Is this an expensive...
look on the lid. see where the prong is.
look on the washer where the prong goes. try to clean that spot, lots of times it's got a build up of lint . the initial wash cycle will moisten the build up preventing it to function properly.
Feb 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My ps2 reads disks but it doesnt read good. cutscenes are always freezing and the game acts weird and freezes after 30 mins or more.i opened the top put a disk in and pressed the 2 buttons while it was on...
well mabey it may need dusted or mabey the copper strip is ripped or damaged or it could be the laser stuffed or it could be your disk isnt the correct format or the disks damage. If the back of the disk is purple it may mean it aint the right format. Just a few possibilities mate ;)
Dec 13, 2009 | Sony PlayStation 2 Slimline Console
My son tripped over our friends ps2 and it fell to the floor upside down. The PS2 goes but the drive does not go.Any ideas how to fix this problem" Thanks
There are quite a few things that can cause a disc read error on the slim PS2. The most frequent is a bad laser, however, here is some useful troubleshooting info:
1. "Lid Closed Sensors" There are two "lid closed sensors" in the slim PS2. In a fall, it's possible that one or both have become damaged. Remove the top of the PS2 and try depressing both sensors with a game inside. The laser should move up and down at least???
IF YES, try again with the lid on... if the laser doesn't move when you close the lid, then the top casing of your PS2 cracked in the fall and is no longer depressing the lid closed sensors.
==> If the laser moves up and down OK but does not read discs, your laser was damaged in the fall. See below for a website with more troubleshooting info, pictures, and replacement cases and lasers.
http://store.richspsxparts.com/slpsnospdi1a.html
IF NO, you have a bad lid closed sensor -- these are not really replaceable easily -- you may be better off replacing the whole PS2 if one or both of these lid closed sensors goes bad.
Nov 17, 2009 | Sony PlayStation 2 Slimline Console
Ps2 slim will not spin disk i have cleaned everything inside everything seems to be working normally yet the disk wont spin
If you have removed the cover and cleaned the glass laser eye lens unit, then the laser lens motor is faulty.
Nov 10, 2009 | Sony PlayStation 2 Slimline Console
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Jul 26, 2009 | Sony PlayStation 2 Slimline Console
My disc wont spin
Hi....
It's probably a broken disc brake post . It comes down off the cover and pokes into a square hole in the back-right-hand side of where the disc lid hinges.
If there's no post the disc wont spin when you close the cover.
If it's broken you can drill a spot where the other one was and glue a plastic piece in its place.
Mar 23, 2009 | Sony PlayStation 2 Slimline Console
PS2 Slim won't spin disks
Not necessarily, just make sure that the laser is not locking up and its actually moving if not then that right there might be the problem. If it is moving then you might need a new laser. If its that the laser is not moving do not touch it instead try moving the ps2 and making sure that you don't hear any clanking noise inside.
Jun 30, 2008 | Sony PlayStation 2 Slimline Console
My Slim Ps2 crashed!!
hi is your ps2 the one where the lid lifts up to put the disk in if so their can sometimes be a problem with switch on the lid when you press the button to load the game push down on the lid and hold it down and if this is the problem then the game will load.
My ps2 has this problem and i have to put books or bottle of somekind on the lid to keep the lid pressed down far enough so that the switch works and loads the game.
Also you could try cleaning the laser lense you can buy a lense cleaning disk and that will clean it for you and if thats the problem as moving it might have caused the dust to move inside a bit affecting the laser have a go at these ideas then get back to me ok
Mar 31, 2008 | Sony PlayStation 2 (PS2) Console
My sony playstation 2 slim disk wont spin
hey if u just set some thing with some decent wight to it on the back right hand corner or on lid in general it will solve the problem thtas how i got around it
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
PS2 slim Power Problem - Light is red goes green but nothing else.
Hi Leostg,
I have seen this a couple of times.  Lightning or an overload has burned up the motherboard. Its not a fuse, its a fried Emotion Engine processor.   Best advice on dead motherboard is to probably total it unless you can get a low price motherboard replacement. My cost on a new motherboard for slim is about $55.  If you want it fixed, replace the motherboard.  Really you may be able to get another Slim for $55 or less. If you look on ebay  for another motherboard do not take any chances on used motherboards. Go for a broken slim model that will boot up but want read discs. When you get one that boots up, use its motherboard in your Slim.  This will be your best deal at getting your slim up and running once more.
Please give me a Solved vote. I believe you only get one vote and its locked.   I have put a lot into your solution and hope you will show appreciation by voting solved.
Oct 16, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Compact System Shelf System Logo
147 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
