Question about KitchenAid KESC307 Electric Kitchen Range
KitchenAid Superba when turning top knob, sparks and short was caused. where can I part parts and how to replace, no manual availabe or specs. HELP
  • 1 more comment
  • Anonymous Mar 18, 2008
    Turned on right front burner, sparked and then shorted out. None of the burners work now. :(
  • mrobby May 12, 2008
    We had the same problem and now it wont work at all. Any ideas
  • fencer51 Apr 02, 2009
    While cleaning one of the knobs sparked, smoked and now nothing works. Kitchenaid superba model kesc307hbs4
I have a kitchenaid superba stove with no operating manuel.Can any help to get a manuel.
Posted on Apr 14, 2008
Http://www.kitchenaid.com/custserv/service.jsp
Enter your model number and it will give a listing of the manuals available to you.
Posted on Feb 24, 2008
Http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209753620.pdf
Apparently it's not a Kitchen Aid, it's made by Whirlpool: kgst307hbs0
Posted on Jun 01, 2008
    New Friend:
Pull off the knob that turns the burner on/off. Tighten the thin bolts that you see surrounding the stem that the knob covered. Just use your fingers. Put knob back on. Done! One of my knobs needs this repeated every 6 months or so. Joan
Posted on Feb 17, 2013
  • Joan McGuire Feb 17, 2013
    Joan
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28³??" (73.0 cm) H x 26³??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
Hi, I have a KitchenAid KSRB25FKSS02 and our refrigerator is not cooling and it is already set to the coldest setting, but our freezer is working just fine.
This is a fairly common problem and is likely caused by the failure of a concealed fan that is responsible for distributing cooled air from the freezer section to the refrigerator side.
SearsDirect parts department has full information on your KitchenAid fridge at the link below:
KSRB25FKSS02
The fan I suspect is shown here:
Distribution parts
Looking at the various pages should give you an idea if you consider this a DIY task or call a pro.
Jul 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ignotor problem on kitchen aid superba
if it takes that long its either the spark moduel or the sw / if all the burners do the same replace the spark moduel and if only one does this replace the sw . some sw kit require all sw tho be repl as they come in a harnes. pre wired. mm hope this helped / feed back pls ..
Feb 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Can I trigger the KitchenAid Superba KTRS25Q ice maker to fill?
THERE IS A WAY TO (JUMP) THE ICE MAKER BUT I DONT RECOMEND IT BECAUSE IF YOU JUMP THE WRONG WIRES YOU CAN DAMAGE IT. TAKE THE COVER OFF THE ICE MAKER AND LOOK IN THERE IT MAY SAY HOW. OR WAIT
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | KitchenAid Superba® (KTRP22KRWH) Top...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Over temperature alarm on KitchenAid Superba Refrigerator
Remove the screws from the bottom grill cover. Use a vac brush to clean out that area. You should also pull the frig out from the cabinet and vac behind.
Also, you can go on kitchenaid.com and download a product manual to replace your lost manual. Click on customer care and select "Locate Manuals & Guides."
Mar 31, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
In door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Jan 07, 2009 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid superba dishwasher leaking
heres a link to your part pook up, pg 6 number 4-5-6 is what i would assume your talkin about, its where the water comes into machine itslef, easy enought ot do your self, simply held on from the inside with gasket and nut. call local parts dist or whirlpool direct for parts
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194206.pdf
Nov 09, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid KESC307 Electric Kitchen Range Logo
2,809 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
