Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Gas Dryer-triple beep
Dryer won't run, no matter what cycle you try to use.
I did try replacing the thermal fuse. Didn't work, it's the right fuse, brought it with me when replacing.
Any other ideas? or options?
Thanks!
  • Luckydad Feb 15, 2008
    Yes unfortunately the panel still works, so I might have to go the route of calling someone in....can't believe I said that. Ha! Ha!
  • he4dryer May 03, 2008
    The lead lights will turn on, but when you hold down the start button all i hear the a click sound. Where is the Thermal fuse located?
  • 24 Answers
ALL Kenmore HE's use tiny surface mounted micro buttons under those large plastic buttons you press and over time some stick.. some even stay ON or just die completely.. sometimes it's just moisture inside the button others its just worn and bad.. I was lucky.. on mine I removed the control panel and used a hair-dryer to remove the moisture (basement) upon re-installing it the far right "beep when done, low, high, OFF" kept rotating LED's (lights) meaning it's stuck down or connected permanently.. This didnt affect it but it's annoying hearing the beeping.. upon next removal I intend to remove and replace all the buttons on the control unit.. IF i can find them at the electronics store as they are very TINY..
Posted on May 17, 2008
Did you have any lights at all on the panel? I just took off the User Interface as going through the troubleshooting guide I found underneath the control panel led me to that solution.
Posted on Feb 12, 2008
  • DIYRLG Feb 12, 2008
    I'll hopefully, get a new one tomorrow and will let you know if this fixed my problem.
  • DIYRLG Feb 21, 2008
    Sorry for the delay, hopefully, you were able to get it working. Mine was dead, finally got the part, installed it and it works! I think next time, I'm going with the old single start button and dial timer!!
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer won't start
I had the same symptoms and it was a bad motor relay. This happened twice within 5 years.
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE4 dryer and it is not heating up. I changed the coil and cleaned out the lint. Is there a reset button?
If it isn't heating up but running otherwise, you probably blew the thermal fuse. The thermal fuse is often blown by the high limit thermostat going bad, and thus may need to be replaced also.
Mar 10, 2010 | Kenmore Elite HE4 Electric Dryer
No heat
its complicated and not able to explain on this page but in any case the unit will have to be completely disassembled and if the igntr bad the thermal fuse ok but more than likely just the thermal fuse....... again its just more work than most people can perform but the first thing is the top has to come off first
Aug 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Gas Dryer HE4-Panel Switch is not Working
repl/ touch panel ,were the front push buttons are the whole assembly ,,
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
133 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
