Question about Canon PIXMA MP530 All-In-One InkJet Printer
No knowledge of how to make printer work
Don't know if I downloaded the software needed for printer to work. I press print and it says in Bold letters PRINT under it is says Error while Printing.
I was thinking I didnt download it right and or I am not following next step.
  • 2 more comments
  • Notblond Feb 11, 2008
    os x 10.4.11
    I was sure I Was supposed to enter the serial numbers from MP530 when installing. That hasnt come up yet.
    When downloading some things. Just before it is downloaded it says mounting failed.
    I have the manuals, CD ROM, easy setup manual, so i should not download this file?
    Somthing is wrong with downloading. like i already said
    In the future I also would like to download somthing order to listen to radio station over the net. Quicktime maybe
  • Notblond Feb 12, 2008
    HIPPITY HOORAY! Im printing
    No comment needed
    Thank you very much Sir.
    Genius:
  • 3,587 Answers
Ok..one thing at a time..what is your computer you're using with printer? then, the drivers are here if you still need them. got backup?
Posted on Feb 11, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 11, 2008
    get the mac driver(dmg file) third one on the list, and then try it again, please.
  • Patrick Michaels
    Patrick Michaels Feb 12, 2008
    sounds like more than one problem on your system. Hope you find what you are seeking here. I can help you a bit more.
    check this link out
  • Patrick Michaels
    well..better than an Inappropriate, I suppose. I accept your vote with all due gratitude.
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Downloading... In bold letters on the front. Opens up says downloading along with lg and verizon wireless symbols. Won't turn off or do anything else.
Needs to have the software reloaded, you can do yourself, try this link for step by step instructions, http://bit.ly/LGphoneUpdate
May 21, 2010 | LG enV3 VX9200 Cell Phone
My printer only bold
Print head of cartridge needs cleaning. Open HP Solutions Center and look for printing problems and follow instructions to print a test page and then clean the print head if the test shows a problem.
Alternatively, remove the ink cartridge and clean the print head (the rectangular metallic plate with numerous tiny holes on the underside of the cartridge) carefully using a very slightly moist cotton bud. Do not rub hard, just a few gentle wipes.
This problem often occurs when the printer has not been used for some time, or when the cartridge has been incorrectly installed.
Dec 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer won't print color
Please check your printer driver to make sure that you don't have a "Print Black and White Only" or "Print Gray-scale Only" set in the driver.
If you do, simply iunb-ch3eck the box.
Don
Nov 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
I need to download a owner/user manual, Toshiba 32C3030DB
Read front of TV. Look for Brand Name. Write Down.
Go to back of TV. Look for Sticker with bold print and confusing random letters like LSD-4463
Type www. into web browser. Type brand name you wrote down before. Type .com, press enter.
Find word "Search" - type in confusing letters. Follow prompts.
Oct 12, 2009 | Televison & Video
When printing from word 2007 on vista bold type is gibberish
Try re-installing the printer driver(s) first. If no luck, then un-install the printer completely, reinstall and try again. You may also have an issue with an incompatible driver with Office 2007. After reinstalling the drivers, try to print a test page and see what happens.
Apr 17, 2009 | Brother MFC3240 Multifunction InkJet...
Out of memory printing across paper
you need a tool to reset your printer if you dont have it let me no
Aug 26, 2008 | Epson Stylus Photo R2400 InkJet Printer
Bold letters in Acrobat 8
on adobe click on Edit>Preference>Page Display>Rendering>uncheck Enhance thin lines.
Mar 11, 2008 | Adobe Computers & Internet
When color printing, looks blurred, but not.
You need to align the cartriges. If you have the HP software installed on your machine, you can just open that and click on the align button. If not here is the link to download the software:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?&lang=en&cc=us&pnameOID=446154&taskId=135&prodTypeId=18972&prodSeriesId=446153&lang=en&cc=us
Just select your operating system and then download the North America/Western Europe full software solution under software. This should allow you to align your cartiges. Just follow the instructions when aligning. Hope this helps you out!
Nov 06, 2007 | HP Color LaserJet 2600n Printer
Does not print lowercase "f"
This is definitely a software problem. Or pssibly a keyboard problem. Not as printer or driver issue.
May 18, 2007 | HP LaserJet 2200D Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
