Question about Digidesign Mbox 2 Barebone
Static on my mbox system
I'm having trouble with static or noise on my tracks. i can hear it slightly before i record a track but when i play back a recorded track it overpowers my instrument or vocal.
I had the white noise static issue as well. The problem was the USB cord that connects the mbox to the cpu. I switched it out. Another issue could be the hardrive that you're allocating your files to. If you're using an external Hard drive Make sure that its formatted for Recording Transferring & Playback. When the noise appear, stop your session and toggle the playback engine between 1024 and 2048. It should stop the noise momentarily.
Posted on Apr 27, 2012
    Problem Solver:
  • 6 Answers
Well it all depends on what program you are using to record your music you will need to activate the noise reduction filter. or lower the volume on your mic but not on the program. Therefore your mic will not pick up any noise in the background and you will still have the same music quality.
Posted on Feb 12, 2008
I have a mxl 990 microphone and its hooked up to a Pro tools LE 8 Mbox Mini . when im recording on protools or any other software with this mic, i hear a static/popping sound and it records the popping...
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise. Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away. somervta_0.jpgThis is what the dialogue might look like. another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
Jan 17, 2011 | M-Audio MXL 990/991 Recording Mic Duo and...
Play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Mar 31, 2009 | Audio Players & Recorders
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
I have a snap back delay when I try and record using my m-audio and protools. I can hear a slight delay in my headphones to what I'm actually playing. How do i get rid of this?
Hi emmastevens
what you are hearing is latency(delay) in the electronics, software, and maybe your computer is producing some problems also. Have you tried to monitor yourself direct from a mixer before you feed the signal into the MBox.
regards
Graeme
Apr 08, 2008 | Audio Players & Recorders
Digidesign Mbox  2 Barebone Logo
1,642 people viewed this question
Top Digidesign Computers & Internet Experts
Marvin
Marvin
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
