Question about Apple iPhone Smartphone
I phone has incorrect own phone number
Incorrect own number displayed in on top contacts. also in summary page on itunes
V1.1.2 simfree
Try out with this,
add the country code at the first of your contact number.
Posted on Feb 24, 2008
I have an n13134 phone, is it possible to block a number ringing my phone ?
You're best bet is to always use the method provided by your carrier service. Per example- I have Verizon: My Verizon > My Plan & Services > Family Safeguards & Controls. My Plan & Services is located at the top of the page. Click View Details & Edit (located on the right in the Usage Controls section). Click Manage Blocked Contacts (located in theBlocked Contacts Summary section) to view blocked numbers. -- This is provided from their website.
----**This will prevent phone calls and voicemail from reaching you!
Oct 24, 2017 | Cell Phones
Want to synchronize my Ipone 4s with gmail
Download google sync and that will sync contacts calendar and notes to outlook and when you sync with iTunes it should copy from outlook. You might have to select outlook as a source in iTunes though.
Sep 08, 2012 | Apple iPhone Smartphone
Phone number backup
You can do it via following steps.1.Update iTunes to the latest version if you have not updated recently. To find out if you need to update, launch iTunes and click "File" followed by "Check for updates." If you are on a Mac, click "iTunes" followed by "Check for updates." If you do not have the latest version installed, a dialog box will appear asking you if you want to download the latest version. Click the "Download iTunes" button.
2.Connect your iPhone to your computer using the USB cable that came with your iPhone. iTunes will automatically recognize your iPhone and an icon will appear in the left-hand column of iTunes.
3.Click the iPhone icon and the "Summary" pane will appear.
4.Click the "Contacts" tab located across the top of iTunes.
5.Click the check box next to the "Sync contacts with" field.
6.Click the drop-down menu in the "Sync contacts with" field and select a program to sync your contacts with. If you are on a Windows machine, you can choose from four options: Yahoo! address book, Windows address book, Google contacts, or Outlook. If you are on a Mac, your contacts will be synced with the Address Book utility.
7.Click the "Sync" button and all of the contacts on your iPhone will be saved to your computer's address book. Included in every contact will be the contact's phone number. Subsequent syncing will add any new contacts you have entered manually on your iPhone. Hope it can help you.
Oct 25, 2011 | Apple iPhone Smartphone
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
I cant send any music from itunes to iphone how do i set it up to send muic to the phone i have opened up iphone
1. Download iTunes.
2. Connect your iPhone to the computer.
3. On iTunes, you should see your iPhone listed under Devices.
4. Click on your iPhone.
5. Go to the Music, Applications, TV Shows, and all those other tabs and set your preferences.
6. Click Sync.
Now you can send music from iTunes to iPhone.
Sep 26, 2009 | Apple iPhone Smartphone
Iphone disabled connect to itunes
Here are your instructions from the website below.
Reset your iPhone Passcode:
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number http://www.knowyourmobile.com/appleiphone/apple_iphone_userguides/4684/how_to_password_protect_your_iphone.html Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2008 | Apple iPhone 3G
How to sync contacts from iphone to outlook 2003?
When you connect your iPhone to the PC that you always sync with, Go to Info tab, Check the box Sync Contacts with: and select Outlook. Then make sure that you check the box Put new contacts created on this phone into the group: and select a subfolder in your main contacts folder.
This way, all the contacts from your iPhone will be saved into another folder in your main contacts folder of your Outlook PST.
Let me know if you have any questions.
Thanks
Sandeep
Jan 30, 2008 | Apple iPhone Smartphone
Insert an unlocked???
Try clicking the 'Restore' button on the Summary page in iTunes, when connected to a PC. If that doesn't work, you'll have to take the phone back to an Apple store.
Jan 24, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
75 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
