Question about Panasonic KX-FHD351 Plain Paper Thermal transfer Fax
Panassonic KX-FHD351 paper problems
Problem with FAX Machine wil not pull paper through.
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Something in the way: paper, paper clip or tires not picking up paper. Clean with alsohol then try.
Posted on Feb 15, 2008
Panasonic kx-ft77 paper jammed and fax im memory
I have a problem with the fax machine in question is panasonic kx ft77 . When receiving a fax error expel warm up and stop receiving the document. Or does anyone know what the problem is and how to fix it ? Thanks in advance
Aug 16, 2013 | Panasonic KX-FHD331 Plain Paper Thermal...
Print missing from one side of image
Check the film if inserted properly, or the the film is got damage one side
Oct 18, 2011 | Panasonic KX-FHD351 Plain Paper Thermal...
Transmit Error
To eliminate a machine problem, make a copy of something; you are using the scanner to verify if the mechanics are OK.
To eliminate a phone line problem, take the fax to another house or office and try there it again.
Oct 30, 2009 | Panasonic KX-FPG391 Plain Paper Thermal...
My Panasonic kx-fhd351 won't feed paper to receive a fax.I assume I need to clean something, but I am not sure what and how.
Does this model also act a copier? If so does it make a copy? If so mite be fax issue. Use alchol to clean rollers, remove draw and clean them.
Aug 15, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
Clean Fax KXFHD351 Panasonic
Nope No mirror, try cleaning the drum corona wire. Gently clean wire with a #2 pecil eraser to remove any dirt, then open fax sheet feeder and GENTLY clean with alcohol wipe across the light bar scanner. Paper dust builds up on this.
Jul 08, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
Fax Memory Full
Have you tried you u n plugging power cord and plugging back in?
Sep 26, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Paper problems ><
try cleaning the tires with alcohol
Feb 11, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
When I send faxes the reciever gets a different fax caller ID
Ring 13 2600. Tell them you bought it (NOT SECOND HAND) and you lost the manual, Explain the problem and they should give you an answer for free!
Jan 28, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Faulty fax machine
You can try cleaning that roller with a rag and some rubbing alcohol. Scrub it really good all the way around and that should help.
Aug 02, 2007 | Panasonic KX-FHD351 Plain Paper Thermal...
Panasonic KX-FHD351 Plain Paper Thermal transfer Fax Logo
60 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
