Question about Mitel Superset 4025 Corded Phone (mitsup4025)
4025 wont work....
I unplug my 4015 and plug in my 4025... after the phone line lights each lite up the phnoe messages states waiting for comm
I thought these phones were plug and play. What do i need to do? thanks in advance for your help
  • 3 Answers
You cannot change models like that without changing the configuration for that extension in the phone switch. If it's configured as a SS4015, then you can plug any other SS4015 into the jack. If you want to change it to a SS4025, then you need to reconfigure the extension in the switch.
Posted on Mar 05, 2008
1499 Light will not stop blinking as if someone is on hold. Even when I pick up the phone.
My first guess is this button may be programmed as a message waiting indicator light for ext 1499. Go to the physical desk location of ext 1499 and see if the message light is on. Clear the message waiting and the companion appearance of this line on your phone should clear. Hope this helps.
Apr 14, 2014 | Mitel Superset 4025 Corded Phone...
Mitel superset 4025...mailbox is full but no messages
Try to restart the phone. Unplug it for 10 minute and then start it normally...
try this and let me know
Mar 23, 2012 | Mitel Superset 4025 Corded Phone...
I have a Mitel Superset 4025. The "message" button was somehow reprogrammed so that pushing it now calls the operator, I can access my VM using "8" but the message waiting light is...
it's because the operator set a message to your phone. You need to leave the handset on the cradle and push the message button. Read the display and follow the prompts. You should be able to clear the message.
Apr 27, 2011 | Mitel Superset 4025 Corded Phone...
Phone isn't working. Message flashing says "Waiting for synch"
This happens on the older software levels of the Mitel phone systems when the phone type programmed does not match the phone type connected. Example: if the phone system programming has a 4015 phone type for that port and you connect a 4025 phone you will get this result. Another cause could be the port you are connected to is analog(used for analog devices such as fax, credit card, modem, or standard single line phone) instead of digital; you would get this result even on the latest software levels.
Assuming that this is the same phone that has been at this location and was working previously, try a different working 4025 phone at this location. If the different phone works, then the problem is in the phone and needs to be sent for repair. If the different phone doesn't work, change the line cord to eliminate possible bad line cord. If the phone still does not work, the problem could be in the outlet, building wiring or in the telephone system. At this point you likely need to call a service technician to track where the problem is.
Dec 10, 2010 | Mitel Superset 4025 Corded Phone...
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
Need to clear messages from phone
Here's a link to a user's manual for your phone.
Page 26 discusses message handling.
I hope this helps you. Good luck!
Jul 09, 2010 | Mitel Superset 4015 Corded Phone
Model 4025
In the days before voicemail, Mitel had a "Call Me Back" feature that would light the MWI. We now use the MWI for voicemail, but the capability is still there. You can solve it several ways.
1. Go to the blinking phone and press the Messages button. One of those should be "Call me back". Press it and when the other party picks up, the MWI should turn off.
2. Look up the FAC for Message Waiting - Deactivate in your phone switch. On my switch it is *91.
Feb 13, 2008 | Mitel Superset 4025 Corded Phone...
Super set 4025 wont work
1) The phone cannot communicate with the switch. 2) Make sure your connections are good at both the jack that you plug the phone into and the block or connection coming from the Mitel switch. What Mitel Switch do you have?
Aug 17, 2007 | Mitel Superset 4025 Corded Phone...
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
304 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
