Question about RCA TruFlat 27F520T 27" TV
Parental Lock we have a proscan ps35123 television and when we shut it off and went to turn it back on, a parental lock appeared and now all we have is a black screen with parental lock appearing in blue letter. we don't have a manual and the remote is not responding to anything, all the works is the power button and volume buttons on the front of the t.v. How do we remove the lock? BLACK SCREEN I'VE LOST THE REMOTE LONG AGO.... THE POWER BUTTON WORKS ,VOLUME WORKS & THE INPUT BUTTON WORKS... I'VE PLUGGED A GAME SYSTEM INTO BOTH SETS OF RCA JACKS & TURNED THEM ON & IF YOU PUSH THE INPUT BUTTON OVER & OVER YOU HERE PS2 COME ON....PUSH AGAIN XBOX GAME COMES ON WHAT CAN I DO!!!!!!!!!!!!!!
  • Anonymous Oct 16, 2008
    I have the same problem but I have the remotes: when it turnes off I see some small numbers???????
    President:
  • 3,130 Answers
Without an original remote, I'm afraid my friend, not much
Posted on Feb 11, 2008
I must have touched the parental lock now I can't turn tv back on, it says will shut off in 6seconds, it's a Polaroid FLM-1507 HD19 inch flat screen tv.
It might not be to the wrong settings of parental lock. It sounds to be it main boards' fault. Contact any service technician.
Electro help
Jul 21, 2014 | Televison & Video
I have a Proscan 42LA45H lcd tv that I just bought but the parental lock was set and the default 0000 doesn't work! Help!
looks like you have a "clean all" selection in the menu under PARENTAL. See pages 15-17 of owners manual, the clear all funtion is explained at the top of page 17
(5) CLEAN ALL
SEE WEB SITE:
http://www.searspartsdirect.com/partsdirect/user-manuals/42la45h-proscan-parts-lcd+television-manual
Apr 15, 2014 | Televison & Video
How do I shut off or disable TV Guardian?
Hello
Setting TVGuardian®
Example:
To set "TV Mode Strict", "TVG CC On" and "TVG CC Ch
CC2"
1* Press [SETUP] in the stop mode.
The setup screen appears.
2* Press [ => ] to select "Parental".
3* Press [ENTER].
"Parental" screen appears.
4* Press [Down Arrow button] to select "TVG Mode".
Note:
If the parental lock is set, the highlighted box does not
move. You must enter the password to release the
parental lock first.
5* Press [ENTER].
The submenu ("Off", "Moderate" and "Strict") appears.
6* Press [p] to select TVG mode to OFF at this window, if it is selected strict.
OK.
Jul 13, 2011 | Sanyo DWM395 DVD Player
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Do not have the password to unlock the TV. Whenever, I turn it on it's asking for the input password and the default is no longer 0000.
I'm not sure what TV you have but many times you can enter 5898 as the password and then it will allow you to select a new one. I hope it works on yours.
May 20, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Parental lock on mitsubishi cs-35203 tv--have sony commander
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Mar 28, 2017 | Televison & Video
Parental lock
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Parental Lock
Try unplugging the tv for a few minutes. This reset the front panel lock on my JVC tv. I got it from the manual, which I found at the JVC site by Googling the specific model of the tv along with JVC and manual. I found the manual right away.
Jan 12, 2008 | Televison & Video
Unlocking the parental control
my jensen ts2750j screen turned blue and a red lock is in the corner... how do i get it off
Nov 06, 2007 | Jensen TS2750J TV
RCA TruFlat  27F520T 27" TV Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
