Konica 3135 p17 error, wont go away
We just got this baby donated today. WE replaced one of the "door" panels(the top one) on the right side but the error wont go away.
where is the sensor that we might tap into to get it to go away. Copier wont work until it goes away.
The error is p17 which means right door,
  • 168 Answers
Check the rear side of the machine in the opening. You should see a small tab on the rear side of the door. This tab is supposed to go through a small slot in the cover that would then contact the door sensor/switch to tell the machine that the door is closed.
If you located the little slot, you can try rolling up a piece of paper putting it in the slot and see if you can trick the machine to think the door is closed. If you can do this then you know that the sensor/switch is working and then you would have to concentrate on the door tab that is supposed to go through the sensor. Unfortunately, if you get the machine to think the door is closed with the paper trick, you still wont be able to make a copy cause the door needs to be closed in order for the rollers to feed the paper upwards. But at least you would be able to narrow it down.
If you have any other questions, feel free to ask. I even still have some contacts for parts if needed.
Please remember to leave a feedback if my suggestion helped.
Have a good day.
Mac.
Posted on Feb 12, 2008
I have Konica Minolta B250it does not warmup.the fused unit is cold and the touch screen is not responding just freezing. I have tried trouble re-set changed fuser unit. Changed control panel nothing is...
Fuser Error is not getting reset.
Try to look into the Right Door SWITCH which is located behind the Front Toner Door.
U need to remove front cover and u will find switch back of steel cover.
check the actuation once u close right side door, it might not be on or off by opening and closing right door..
Jul 21, 2017 | Konica Minolta Office Equipment & Supplies
Closed 1st side cover konica minolta bizhub 185
Check the 2 actuator at Right Door assy, may be broken, so while closing it is not blocking/hitting the sensors on body.
check properly - at Rear-Top & Front-Below on Right Door assy.
Dec 09, 2016 | Konica Minolta bizhub Office Equipment &...
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 password reset
if you are just wanting to disable the password function on the machine here is the steps to do that:
1.turn the machine off
2. hold the 2 and 5 while you turn the machine on
3.press the p button then 0 5 then press the p button
4.press 0 then start
5 turn the machine off then on
this disables ecm function so you wont have to enter a password to make a copy
Nov 25, 2009 | Office Equipment & Supplies
Konica 3135 error code 41
41-3 Error Code is an Optical return problem. The Scanner is not returning back to home position like it should.
A common problem with this model machine is a small black gear on the drive motor cracks or ovals out. If you can locate this gear, you can try placing a drop of super glue on it and see if it will hold. This works if the gear is ovaled out. If it is cracked or split then you will need to replace this gear.
Hope this helps a little.
Feel free to post another question if you need more help.
Good luck,
Mac =)
Jun 26, 2008 | Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
65 people viewed this question
k24674
jasbo
jasbo
