Question about Minolta MF1600E Plain Paper Laser Fax
Minolta fax machine 2800
My minolta fax 2800 machine is jamming and stopped taking the paper when faxing a document. It reads paper misfeed but the rollers are not taking the paper anymore. What do I do?
  • Anonymous Mar 12, 2014
    HOW DO I PULL A CURRENT METER READING OFF OF MY BROTHER 2800 FAX MACHINE
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Minolta Master
  • 1,362 Answers
Clean rollers with alcohol, it should pick up ( for a while) rollers will probably need changing
Posted on Feb 14, 2008
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
CHECK 5100
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
Feb 20, 2012 | Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Misfeed detected but no paper jam
    Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
    for the image unit try this site
    Precision Roller Printer Toner Cartridges Parts and Supplies Office...
    as for the adf replace!!! the rollers all three try the same site above
    Nov 03, 2009 | Minolta Di251 All-In-One Printer
    Memory RX, Recording Printing JAm
    yes you can! if you really want it! you may enter the menu and in printing menu look for rx and press enter, or look for print from memory! it should work
    Nov 03, 2008 | Minolta MF1600E Plain Paper Laser Fax
    Changing date on Minolta 2800 Fax
    You might try www.minolta.com to download a user manual. Otherwise you will have to scroll through the menus for SETUP
    Oct 20, 2008 | Minolta MF1600E Plain Paper Laser Fax
    Minoltafax 2800
    http://www.smpcshop.com/MINOLTAFAX-2800-3800-p-1150.html
    Jul 23, 2008 | Minolta MF1600E Plain Paper Laser Fax
    Minolta MF1600E Plain Paper Laser Fax Logo
    158 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    David Burkhart
    David Burkhart
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
